Old 02-06-2001, 10:44 PM   #1
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post external wastegate:classy but is it worth it?
external wastegates seeem to last longer and offer better persomance than conventional integral wategates, but how does IHI stand up to this?
WRXwannbe is offline   Reply With Quote
Old 02-07-2001, 01:19 AM   #2
doripreza
Member#: 574
99 Impreza RS
Post
umm, i guess this is a preference thing but i always go by this rule... if you are planning on running over 9lbs get an external wastegate... but almost all IHI's use an internal.. the bigests complaint I've heard is that internals don't respond well to higher boost levels and externals can boost surge, I'm using an external
doripreza is offline   Reply With Quote
Old 02-07-2001, 05:44 AM   #3
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Wink
The externals are better for high boost aplications. The internals just cant bleed off like a much larger external can. Besides nothing says im gonna rip you a new one like the sound of an external wastegate opening up and venting to the atmosphere.
Josh
scoobiejosh is offline   Reply With Quote
Old 02-07-2001, 08:41 AM   #4
XT6Wagon
Member#: 524
04 STi
Post
Depends on the internal, and the application its on that deturmines IF a external will be better. The better IHI's have a completely different exaust bore for the wastegate, so in perfromance it is very much like a external. It doesn't have the easy adjustment that most externals have, but you save several hundred dollars and alot of room under the hood with the internal.
XT6Wagon is offline   Reply With Quote
Old 02-07-2001, 09:21 AM   #5
shiv
Member#: 607
Post
Hi guys-- It's not just bore size that makes external wastegates superior to integral ones. It's also because they cause less exhaust gas disruption in and after the turbine housing. This usually accounts for a few extra percent turbine efficiency, which is hard to come by otherwise.
Shiv
shiv is offline   Reply With Quote
Old 02-07-2001, 11:08 AM   #6
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
now with the external wastegate, can it be computer controlled with an ecu? or do I have to buy and replace springs?
Old 02-07-2001, 11:36 AM   #7
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
Post
you can controll it with a Boost Controller. If you have an aftermarket ECU (Motec, Haltech) that can controll boost, then they can.
Josh
External Wastegate VF39 06 WRX - Worth It? All4BeSpinnin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 12-04-2009 08:07 PM
Bigger plug spark...is it doable? Does it hurt things? Is it worth it? kaisersouse Normally Aspirated Powertrain 8 01-27-2006 06:35 PM
is this legal? if so is it worth it? svek Interior & Exterior Modification 22 08-26-2005 11:37 AM
I am sick... but DAMN it's worth it!!!!!!!! MK19_ South East Region Forum 4 07-20-2005 09:58 AM
David Cooperfield is in my town this week. Is it worth it? Mud Pig Off-Topic 11 04-25-2005 03:45 PM
