Old 02-05-2001, 09:57 AM   #1
joostin420
Member#: 1046
2013 WRX Wagon
Lightbulb my short throw shifter lever draft, what do you think?
well here it is, my hopefully final draft of my shorter shifter design. please let me know if my calculations are correct. i will be off to the machine shop in 4 hours so any input would be greatly appreciated. thanx for everyones help already.
<IMG SRC="http://216.242.153.40/MembersList/UserPics/1510/finaldraft.jpg" border=0>
thanx,
justin
joostin420 is offline   Reply With Quote
Old 02-05-2001, 10:03 AM   #2
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Post
Joostin did you increase the distance between the ball at the bottom and the pivot point(as compared to kartboy or cobb)? If you did you may have interference problems between the shift linkage and the hole in the transmission tunnel.
skidplatez is offline   Reply With Quote
Old 02-05-2001, 10:24 AM   #3
joostin420
Member#: 1046
2013 WRX Wagon
Lightbulb
okay, i measured the distance when the trans. linkage was in 1rst gear which i believe is the closest point to touching the surround plate and tunnel.
was in 1rst gear and was touching the metal surround plate and measured distance of height to place new mounting of center of the bushing housing. at this position i had about 1/8 to 1/4" of space before hitting the tunnel under the metal surround.
so if it does hit the metal surround barely i will be able to trim the surround, like most people with other levers have to usually do anyway.
i believe that my height of the center of the bushing housing is pretty darn close to exact as the kartboy/cobb/etc. (but mine removes the angle of shaft with a straight shaft exactly like the Cobb and imprezars.com lever does)
it looks like my design is pretty darn close to replicating them, but i added a few more features to mine.
i do want to say i am in no way going to produce the lever for anyone but myself people are free to use my design if they want. i in no way want to take away from the market, but just want something else that i made myself.
justin
Old 02-05-2001, 11:33 AM   #4
Derres Catalano
Member#: 3244
2000 2.5 RS
Silverthorn
Post
OK, first of all I still cannot understand why you are trying to invent the wheel. Plenty of kits are already for sale, and some are pretty cheap. Anyways..... I am only saying this because I have already done what you are doing now. Difference is, I have my own machine shop, I am an engineer, and I know that I had to go through 4 versions before I got it right. Why did I do it? Because I had the know how and the resources. If I did not have my own shop, I NEVER would have tried to design and develop my own design. The economics are not there. But by all means... go ahead and try.
I can tell you this, there is a reason why the stock lever has an angle design in. Your design uses a straight single rod, with no angle. You will find that the lever position is virtually unusable for most human beings, not to mention uncomfortable, when there is no angle designed into it. How do I know? Because that how I did mine, at first.
If you want, I would be willing to share with you my working prototypes. And BTW, the distance from the pivot point to the ball/socket center is very specific, and defines the whole short shift motion. Too long, and you cannot get it into the socket because of the linkage interfering. Too short, and you don't get much difference from the stock shifter. I can tell you this because, well, I have prototypes and the first one didn't work because it was too long. Let me know.
Derres Catalano is offline   Reply With Quote
Old 02-05-2001, 11:35 AM   #5
donjuan
Member#: 2248
2012 C63
2012 Silverado HD
Post
Well there you have it.
donjuan is offline   Reply With Quote
Old 02-05-2001, 12:17 PM   #6
joostin420
Member#: 1046
2013 WRX Wagon
Lightbulb
well, i guess that means that my "replica" of the cobb/imprezars.com/etc. that many people enjoy very much, that have the straight design are wrong on there choice of shifter?
i dont know, i think i will at least try what many people have and enjoy very much
thank you for your input, and mine should be done next week
thanx,
justin
Old 02-05-2001, 06:43 PM   #7
Derres Catalano
Member#: 3244
2000 2.5 RS
Silverthorn
Post
MAybe I should have also told you that I am 6'2" tall. That is why the "straight" rod design did not work for me, because it places the shift knob too far away from me in my normal seating position. It was a real stretch.
But it might be OK for you.
Just a tip : superimpose your lever draft onto a draft of the stock lever, keeping the bottom pivot point the same. That will tell you right away how much further the knob will be from the stock position.
Old 02-07-2001, 12:30 PM   #8
joostin420
Member#: 1046
2013 WRX Wagon
Lightbulb
you are pretty tall i am only 5'7", i think it will be perfect for me.
thanx for the input, it should be done sometime next week and i will post the result.
thanx,
justin
FS NJ: STi Shifter Kit, STi Short Throw Shifter Lever, Linkage, Trans Mount SupraToWRX Drivetrain 32 02-27-2009 02:07 PM
FS NY WRX 5 speed sti short throw shifter lever!! REAL CHEAP!! Blueboost Private 'For Sale' Classifieds 0 02-04-2006 06:17 PM
FS NY WRX 5 speed sti short throw shifter lever!! REAL CHEAP!! Blueboost Private 'For Sale' Classifieds 1 01-31-2006 08:53 PM
short throw shifter lever install help! MPREZD Transmission (AT/MT) & Driveline 14 11-24-2005 05:15 PM
my new STi custom front lip, what do you think? VajraTLR Member's Car Gallery 25 09-30-2004 07:29 PM
