Old 07-01-2004, 11:02 AM   #1
Aegon
Member#: 42435
Default Speed Rating Question
OK, so tires have a speed rating. The stock tires are something like V rated, which is good up to 149 MPH. There are other ratings like W, Y, and Z which have a higher speed rating. My question is this:
Does the rating of a tire affect
(a) performance
(b) life
The reason I ask this is because I've seen the same tires offered at different speed ratings. I never drive over 149MPH (I probably wouldn't ever go above 110MPH, and an 90MPH cap would probably work OK for me). Is there any reason I would want to pay for a higher speed rating when I don't go that fast anyway?
Aegon is offline   Reply With Quote
Old 07-01-2004, 11:18 AM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
speed rating effects alot of aspects in a tire ... the most notable are:
Performance
stability
handling
steering response
temperature
and typically the tire life is shorter ..... (but, not in all cases)
Old 07-01-2004, 11:24 AM   #3
Aegon
Member#: 42435
So if I'm looking at a goodyear F1 gs-d3 for example and there is a WR rated tire and a YR rated tire for $1 more per tire, the YR will perform better?
Old 07-01-2004, 11:25 AM   #4
Aegon
Member#: 42435
Also, would I ever notice the performance difference if I never plan on going more than 90MPH or autocross speeds?
Old 07-01-2004, 11:30 AM   #5
Tire Rack Moderator
Member#: 1215
ext. 4362
you really probably would not notcie any difference between those 2 ...... now if you were to compare an "H" rated version of a given tire to a "Y" rated version you would notice a difference
WTB: 2 T speed rated snows superhawk44 New England Impreza Club Forum -- NESIC 0 01-04-2005 01:51 AM
mixing speed ratings? Benjamin Tang Tire & Wheel 1 10-11-2004 01:52 PM
Same Tire Different Speed Rating Silver04WRX Tire & Wheel 2 03-03-2004 03:23 PM
stock tires....V-rated speed rating? fourortwowheels Newbies & FAQs 2 11-05-2001 11:22 AM
speed rating of oem tires... db97 Brakes, Steering & Suspension 6 08-19-2001 02:14 AM
