Old 07-01-2004, 04:36 PM   #1
Converted
Member#: 52838
Default How and when do you check your oil ?
When do you check your oil, after you drive, morning etc ?
Everytime I check the oil it isnt a perfect line across the dipstick, as if the engine is still draining, but even in the morning its not perfect.
Just wandering what you do?
Converted is offline   Reply With Quote
Old 07-01-2004, 04:39 PM   #2
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
I check it all the time, prolly every 100-200 miles, after the engine is full op temp (getting gas or something), let it sit few minutes, one side of the dipstick reads lower than the other for me os i go with the lowest
overdose is offline   Reply With Quote
Old 07-01-2004, 04:52 PM   #3
Converted
Member#: 52838
Ill try that next time I get gas, maybe I let it sit too long before. Thanks
Old 07-01-2004, 05:26 PM   #4
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
I usually check when the engine is cold before i start it in the morning.
If you check it when the engine is warm or after driving, let it sit for like 5 minutes IMO so the oil can drain back into the pan etc.
P
PaulRex is offline   Reply With Quote
Old 07-01-2004, 05:28 PM   #5
dropmech
Member#: 41477
2006 Tahoe that
will pull your bumper off
I usually check it when I fill up my gas tank. So, at least once a week it's getting checked.
dropmech is offline   Reply With Quote
Old 07-01-2004, 08:32 PM   #6
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
the service manuals say to check it with the oil at full operating temperature, but several minutes after the car has been turned off to allow it to drain down.
nhluhr is offline   Reply With Quote
Old 07-02-2004, 12:02 AM   #7
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
tcs007 is offline   Reply With Quote
Old 07-02-2004, 12:57 AM   #8
Converted
Member#: 52838
So about 5-10min after running the car. Cool, good to know Ill try that!
When do you check your oil? subalou1 Service & Maintenance 2 03-19-2005 05:44 PM
When do you changer your oil? da n00b Impreza Forum 30 03-16-2005 02:52 PM
How/When do YOU use your IC Sprayer? makofoto STi Forum Archive 10 08-28-2003 01:47 PM
How often do you check your tranny fluid? Diff? Tkacik Transmission (AT/MT) & Driveline 11 12-10-2001 06:39 AM
How the hell do you check your pm's? ac_gohan Bay Area Impreza Club Forum -- BAIC 4 06-08-2001 06:06 AM
