Welcome to the North American Subaru Impreza Owners Club Wednesday October 7, 2015
Old 02-05-2001, 10:48 AM   #1
Member#: 3731
2000 Impreza RS
Post Egt mounting and installation
I will be getting an Apex-i s-afc. Before I get that I want to install an EGT to aid in tuning the thing.
What is involved in installing the sensor(MY00)? After the sensor, what is the best way of installing the gauge itself? I have not seen any pods for the Subie, and I do not have the center gauge pod from SOA. Any pointers or notes from previous installations?
Any info would be great.
Otaku is offline   Reply With Quote
Old 02-05-2001, 11:04 AM   #2
Member#: 2634
1988 5000 CS Quattro
Tornado Red
You can get the center pod from the dealer for about $65, then you would also need a face plate. Autometer makes A pillar pods also, in single and dual models. After you weld in the bund for the probe (#3 cylinder is the best bet according to local wisdom), there is 2-wire wire to run to a wiring module. That module also takes a power and ground, and you connect the gauge to the module directly. Mine draws power from the 12v power source next to the radio and I'm not sure where it grounds to. I might go for the center pod, as the module takes up some space and the pod mount has a nice area where you can hand the module from. HTH
RyanC is offline   Reply With Quote
Can a aftermarket EGT probe be installed in factory egt locatoin? nicholam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-04-2008 11:35 AM
HELP! STi engine mounts and tranny mounts install jimtweet Tri-State Area Forum 11 04-22-2006 01:29 AM
EGT, Boost and Oil press. gauges. Full install w/ pics. 2phless Interior & Exterior Modification 20 03-15-2006 05:18 PM
How long to install EGT, Boost, and Oil Temp for a noob? Irishman Electrical & Lighting 11 10-02-2004 10:05 PM
EGT Gauge and Probe Installation YonkerzImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-11-2002 09:13 AM
