Old 02-05-2001, 10:09 AM   #1
Guest
Member#: 3993
Post Engine code
A friend of mine has purchased an Impreza JDM version, engine code EJ20BUG. He just wrecked a piston and can't find one anywhere. Any info appreciated (piston part number, engine specifications etc). Thanks!
Guest is offline   Reply With Quote
Old 06-25-2007, 07:48 PM   #2
excello
Member#: 150458
I'm still a newby so i can't open a new thread that's why i'm placing my question in this thread. Hope someone can help me. I've also got an EJ20BUG engine but it's a turbo. The seller told me it came from a gtt from 1997. I took it apart en bought a new gasket set for it and a set of head bolts to. The set was for an EJ20GN impreza/legacy turbo (what the add said) and is the same as the old set but..... the new bolts are 2cm longer then the old ones. And no way they are going to fit my engine. I've been looking and looking (and i'm very bad at finding stuff) but can't find anything about what the length of bolts should be. The seller is also looking but hasn't found anything either till now. The old ones are 18,5 cm from top to bottom and the new ones 20,5 cm. Does anyone know whats going on here and where i could find a list with the length of head bolts....?
excello is offline   Reply With Quote
Where is the engine code on the block engine for a wrx or sti? ejcivicdee Newbies & FAQs 3 08-12-2009 08:37 PM
No engine codes, then bam! 4 codes tamadrumr88 Normally Aspirated Powertrain 10 07-22-2009 05:56 PM
Does anyone know the engine code for the WRX? DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-21-2001 10:49 AM
Check engine codes Kruf General Forum Archive 1 12-17-2000 05:46 AM
