Old 06-23-2007, 06:17 PM   #1
snoopyone8
Member#: 42970
1998 2.5RS BlkDmdPrl
2000 2.5RS SilverthornMet
Default Header Stud Broke, I hate myself.
They were brown and corroded....and what do I do? "I can get em out, noooooo problem"
TINK
I did pb them, I even went out and pre bought new hardware.
Has anybody had any luck with the vice grip deal or should I go directly to a place with proper tools and pay out the ass because Im an overzealous, impatient ass who "just had to go out and tinker alittle."
I hate myself and my wife hates me too.
Thanks in advance for any advice/suggestion/miracle cure.
-adam
snoopyone8 is offline   Reply With Quote
Old 06-23-2007, 06:23 PM   #2
Hawk296
Member#: 14555
1995 Impreza L
Baja
Is this the stud in the head or the bolt/ nut at the rear?
Hawk296 is offline   Reply With Quote
Old 06-23-2007, 06:25 PM   #3
snoopyone8
Member#: 42970
head, of course...
Old 06-23-2007, 06:38 PM   #4
snoopyone8
Member#: 42970
Yeah sorry about that, i screwed up the title, it is one of the three studs.
Crappy day.
Thanks,
adam
Old 06-23-2007, 07:56 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
you can buy left hand drill bits, drill bits that bore holes by going counter-clockwise, sometimes it will loosen or reverse broken bolts or studs. if not, then drill and tap a new hole to the next sized up drill bit. IIRC the exhaust studs are 10 or 12mm in diameter, you could just drill it out at 1/2'' and call it good.
~Josh~
ballitch is offline   Reply With Quote
Old 06-23-2007, 08:35 PM   #6
snoopyone8
Member#: 42970
thanks josh, i just wanted to know if anyone has been successful with vice grips and heat/lube
Old 06-23-2007, 10:20 PM   #7
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
i broke 2 on my ej22 when i did the rebuild...i just ended up paying the machine shop to fix it... it was like 30 bucks or something...
throwing money at a problem always solves it...
other choice would be to helicoil it... which require drilling it out anyways...
Zefy is offline   Reply With Quote
Old 06-24-2007, 06:42 AM   #8
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
they are just studs, should come out.
yarrgh is offline   Reply With Quote
Old 06-24-2007, 05:07 PM   #9
snoopyone8
Member#: 42970
why oh why couldnt Subaru invest a couple dollars in some anti seize...this is crap.
First stud came out with some force, second broke...now im afraid to even go near the other four. i dont want to take the car to the shop but im afraid im gonna have too.
i have been soaking them with pb blaster all day and they still wont budge. i can still drive it with one broken stud but if i break the other four im done for.
has anybody else had this much trouble?
peace,
adam
Old 06-25-2007, 09:15 AM   #10
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
I had one tear up some threads on the way out.. just ran a tap into it to clean up the threads and put a new stud in. It freaked me out for a little while, but I kept reminding myself.., "You can't say you know how to work on cars, until you've broken one of everything on a car." I'm about 20% of the way to knowing how to work on cars.
Were you just trying to get the nuts off or were you trying to remove the studs?
The studs don't have antiseize into the block because you want them to seize to a certain extent... otherwise you'd never get the nuts to break loose. I believe they're originally assembled with some locktite. The nuts are supposed to be copper so that they don't bond to the steel studs.
Old 06-25-2007, 10:08 AM   #11
eightKsi
Member#: 132965
2002 Impreza RS
There's a bunch of tricks, like the PB Blaster, taps, etc., but if you want to do the low-impact, low damage way, try this:
IF you have some threads on the studs that you can get two nuts on. Not sure what you've got to work with.
Keep hitting it w/ PB blaster like you're doing.
Screw two nuts on the threads, and tighten them into each other (use two wrenches to screw them into each other). They should lock together, so you can use it like a bolt head.
HEAT IT with a torch: propane, etc. (this will probably work the best for you)
Use a socket wrench on the two nuts while it's pretty hot.
Loosen a click or two w/ the socket wrench.
Tighten a click.
More PB Blaster.
Repeat.
If that doesn't work, or if you can't get the nuts on it, just take it into a good mechanic shop. They know how to remove bolts, and have lots of experience doing so. It's probably an easier job for them than you think.
Spend the couple bucks, and have them remove this one, and the remaining bolts while they're at it, if you want.
Do NOT get into the left-handed bits/taps/etc unless you really know what you're doing. You can really, really get into trouble there, and you will need to take it into a machine shop/spend some $$ on it then.
I recently ran into the same problem w/ a radiator housing stud on a 25-year old tractor. Same thing: SNAP. A tractor repair shop had it out in 10 mins. Very cheap. Some one who was trying to 'help' me had put vice grips on the threads on the stud, and stripped them all off, so I couldn't try the two-nut trick.
eightKsi is offline   Reply With Quote
Old 06-25-2007, 10:18 AM   #12
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
The best trick I have seen is welding a nut onto the end of the stud and turning it out. Obviously you need a welder to do this but it works extremely well.
Tim Sanderson is offline   Reply With Quote
Old 06-25-2007, 10:39 AM   #13
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Did you take a wire brush to the threads before you started? You need to get the flakey stuff off there...
You can also try using a flathead screwdriver, place it on the side of the nut and tap it with a hammer, to try and break up the rust, hopefully in the threads.
Heating as mentioned, but cooling it with the PB, it may help to work the PB down into the threads better... just make sure you don't burn your car down...
tap on the end of the stud with a hammer, you might get the stud out before the nut comes off.
Old 06-25-2007, 05:43 PM   #14
snoopyone8
Member#: 42970
welt, sucked it up and took it to a shop....i f'd it up bad enough, all i need to do is f it up more.
thank you so much for all of your help and ideas guys, i would have attempted them but i was too nervous...best let the professionals do it.
Why is it that any simple project, meant to pass the time, always ends up costing way too much time and way to much money?
thanks again!
adam
Old 06-25-2007, 06:35 PM   #15
piker28
Member#: 22664
its called the north east and a ton of damn road salt!!
piker28 is offline   Reply With Quote
Old 06-25-2007, 06:53 PM   #16
snoopyone8
Member#: 42970
yup...you would think that Suburu, who specifically markets its product to northern tier regions, would invest in a little anti seize or maybe even a little bit better grade hardware. oh well, what can you do. Like Frank says..."thats life."
peace,
adam
Another @#$%ing Replace 1 or 4 post! I hate myself for even Writing it! but... jwdjwd67 Newbies & FAQs 8 04-05-2008 01:01 AM
Gauging interest (and I hate myself for it): 2000 GC8 JDM RSTI legacy2003 Private Vehicle 'For Sale' Classifieds 54 03-25-2008 09:44 PM
Gauging interest (and I hate myself for it): 2000 GC8 JDM RSTI legacy2003 NESIC Private Classifieds 42 03-15-2008 03:43 PM
I hate myself linux>windows Off-Topic 15 07-31-2005 01:19 AM
I hate myself and want to die alacrity024 Off-Topic 16 10-08-2004 01:22 PM
