Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 07-01-2004, 10:32 PM   #1
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Default Whats the weight on OEM WRX wheel/tire set-up?
Trying to calculate shipping for the OEM 16" WRX wheels with RE92 tires.
MF-DIF is offline   Reply With Quote
Old 07-01-2004, 10:38 PM   #2
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
16.5 w/ out tires
sorry i dout that helped much
RS_to_WRX_swap is offline   Reply With Quote
Old 07-02-2004, 12:03 AM   #3
ultrasonic
Member#: 18006
Without packing materials you can approximate 37-39lbs.
ultrasonic is offline   Reply With Quote
Old 07-02-2004, 12:19 AM   #4
abaxter34
Member#: 34723
fwd FTL!
weighed one wheel and tire yesterday- 37lbs
abaxter34 is offline   Reply With Quote
Old 07-02-2004, 12:59 AM   #5
sonicowrx03
Member#: 41566
I never weighted my tires but I have seen a lot of threads talking about it.
The rims weights 16.5lbs and the actual tire 21lbs
sonicowrx03 is offline   Reply With Quote
Old 07-02-2004, 01:24 AM   #6
nickster
Member#: 49836
03 VF43'd WRX
psm
If the stock wheels and tires are around 37lbs, is 44lbs really heavy for 18" wheels with tires?
nickster is offline   Reply With Quote
Old 07-02-2004, 01:31 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You could do better...or worse....I installed some 19's on an EVO the other day, and even with light tires, the tire/rim was 50.25 pounds ...and that was 25 for the rim.
I used the UPS scale to measure them, so...
Old 07-02-2004, 02:15 AM   #8
nickster
Member#: 49836
03 VF43'd WRX
psm
Yeah, the tires (SO-3's) are also kinda heavy. I think? The wheels alone are supposed to be around 18lbs.
New wheel/tire set up on 07 WRX wagon jlassen Tire & Wheel 3 05-19-2011 12:17 AM
Widest Tire on OEM WRX Wheels? WRXceleration Tire & Wheel 1 07-14-2006 11:33 AM
195/50/16 on OEM wrx wheel? for winter tire... psyber_0ptix Tire & Wheel 2 12-13-2005 10:54 AM
Post your wheel/tire set up and their weights! txl146 Tire & Wheel 8 09-17-2005 01:15 PM
can't find weight of OEM WRX wheels Se3n Tire & Wheel 8 09-23-2003 12:07 AM
