Welcome to the North American Subaru Impreza Owners Club Thursday May 7, 2015
Old 02-04-2001, 08:38 PM   #1
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
Post 02 sensor question please help
ok i recently installed a a/f ratio gauge and i spliced the wire from the slot that says its the front 02 sensor slot. I did so and my gauge does not recieve a signal. what is wrong is it the wrong slot? There is a front and a rear o2 sensor each have a slot and a warmer thing. people with a/f ratio gauges please tell me which wire to splice. Thanx
ac_gohan is offline   Reply With Quote
Old 02-04-2001, 08:59 PM   #2
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Post
You should really try a search...this has been hashed and rehashed at least 5 times in the past.
To answer your question, if you have a MY00+ Subaru, then you need to attach it to the rear O2 sensor. It will work, but your reading will be a little off due the the cat being upstream from where you're reading the O2 content of the exhaust gases.
If you have a MY99- Subaru, then attach it to the front O2 sensor.
Do not touch the warmer signals.
Sean
Sean McElderry is offline   Reply With Quote
o2 sensor question! Please help! minhha2006 Mid Atlantic Impreza Club -- MAIC 6 03-23-2009 11:14 AM
O2 sensor question! Please help! minhha2006 Interior & Exterior Modification 3 03-22-2009 11:35 AM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Engine Management & Tuning 2 07-05-2006 10:50 AM
Crankshaft Position Sensor Air Intake Temp Sensor CODES!! please Help!! GT40R Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-02-2006 05:07 PM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Southern California Impreza Club Forum -- SCIC 2 07-01-2006 06:03 PM
