Old 07-01-2004, 10:58 PM   #1
BurntJamb
Member#: 13538
Default Ok to use torque wrench as main lugnut wrench?
So I got some aftermarket wheels and lugnuts that use a key with 21 mm heads. The stock lugnut wrench won't work because its 19 mm so I picked up a torque wrench (a $25 Craftsman one rated up to 140 ft/lbs) and a 21mm socket.
And here's my dumb question:
Is it okay to use this torque wrench as a replacement for my 19 mm lugnut wrench (which is basically useless now), i.e. can I use this torque wrench for both the removal and tightening of these lugnuts or is it better/required to buy a real (ratcheting) wrench and then only use the torque wrench to check the torque? I just want to make sure I can use the torque wrench to remove the lugnuts since the initial force required to remove the lugnuts will be >> than the torque rating to which they were tightened (possibly > 140 ft/lbs of rotatation in the other direction). Yeah yeah, I'd try it out but I'm too lazy and I figured I'd ask in case I was doing something stupid like ruining my torque wrench by removing the lugnuts.
BurntJamb is offline   Reply With Quote
Old 07-01-2004, 11:07 PM   #2
Brad Nely
Member#: 36998
2000 BMW M Coupe
Imola Red
Brad Nely is offline   Reply With Quote
Old 07-01-2004, 11:17 PM   #3
abaxter34
Member#: 34723
fwd FTL!
from what ive been told breaking nuts/bolts loose with a torque wrench will eventually throw it out of calibration and may possibly damage it beyond repair/recalibration. breaker bars are good.
abaxter34 is offline   Reply With Quote
Old 07-01-2004, 11:26 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Don't use the torque wrench for ANYTHING other than torquing a fastener to proper torque.
Buy and use a big rachet handle or breaker bar to loosen the lugs.
And...I wouldn't torque your lugs over 75ft-lbs.
The FSM says 65ft-lbs....and I usually go 70....
Old 07-01-2004, 11:46 PM   #5
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
the torque wrench is fine for putting on your nuts, but when taking them off, use this:
(or an impact wrench, of course)
nhluhr is offline   Reply With Quote
Old 07-02-2004, 12:03 AM   #6
clark wrx
Member#: 59382
2004 WRX
wrb
The rednecks around must be getting to me because i use a ratchet with a big old rusty pipe.
clark wrx is offline   Reply With Quote
Old 07-02-2004, 08:33 AM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
ss
subysouth is offline   Reply With Quote
Old 07-02-2004, 08:43 AM   #8
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
FSM = F Service Manual?
Well, from the OEM Car manual, I believe that it gives a TORQUE RANGE for your lug nuts -- not a specific torque. This would be the same with most 'wear' bolts like the drain plug. It drives me nuts not being given a specific torque spec.
I want to say the OEM manual says between 68 - 75 ft lbs, IIRC. I will verify this when I have a minute away from work.
But, to go along with the point, Yes, I use a ratchet, extension, and a socket for my replacement to the 'tire iron' they give you. I just keep the lug key in the subaru bag with my rachet stuff. I generally only take the torque wrench with me when I am going to events.
Good luck, and any of the above suggestions are good ones. Don't kill your torque wrench though... especially if it is one of those 'bendy' toque wrenches.
- dow
dowroa is offline   Reply With Quote
Old 07-02-2004, 01:32 PM   #9
YinUCSD
Member#: 44945
06 LGT wag
a breaker bar can be bought for $10 or under from any hardware store. try Harbor Freight, i got two breaker bars there (25" and 13") for $15
YinUCSD is offline   Reply With Quote
Old 07-02-2004, 01:49 PM   #10
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
if you just want something for your tires, a 4-way is wonderful, and cheap...
you get equal push and pull, so it's not likely to come off like the stock iron...
plus you can use it for several differnt cars if needed...
mrbell is offline   Reply With Quote
Old 07-02-2004, 02:31 PM   #11
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Where/what is that?
jblaine is offline   Reply With Quote
Old 07-02-2004, 02:59 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally posted by jblaine
Where/what is that?
...breaker bar...????
Old 07-02-2004, 03:04 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
- dow
FSM = Factory Service Manual....and
and...
Old 07-02-2004, 03:05 PM   #14
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Okee doke.
Never had to touch one and I've never seen one in Sears, etc.
Didn't know.
Old 07-02-2004, 04:32 PM   #15
YinUCSD
Member#: 44945
06 LGT wag
Okee doke.
Didn't know.
its just a really long socket wrench that doesnt ratchet.
Old 07-02-2004, 08:29 PM   #16
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Where/what is that?
It's a Great Neck brand 18" long, 1/2" drive breaker bar. I think they sell them at Ace hardware maybe?
For those talking about using a socket wrench with an extension handle, try a swivel-head breaker bar. It is longer, lighter, one-piece, and once you break the lugnut loose, you can straighted the breaker bar (via the swivel-head) and then spin it like a big screwdriver. Very fast. I've got a shop full of tools and when I'm not using the air impact gun, I prefer this method.
I don't have a 4-way though so I can't comment on that.
Ok to use the spring perch to lower on double adjustable coilovers?? BurtonCR Brakes, Steering & Suspension 0 11-11-2006 10:57 PM
Is Using A Mechanical CEL Fix ok to use with the Utec? Hayaboosted Engine Management & Tuning 2 09-08-2005 12:15 PM
Switching to Mobil1 tonight - ok to use conventional filter? Mizen Newbies & FAQs 9 10-15-2000 02:03 PM
Ok to use stock mounts with WRX Struts? N/A Technical Forum Archive 4 09-21-2000 09:11 AM
