Old 02-02-2001, 09:04 AM   #1
ScoobyDriver
Member#: 195
2001 BH9
Question Pulsing Idle
Hi, Just recently when I warm up my car from cold (anywhere between 30f to -20f) as the car warms up the idle 'pulses' meaning the tach goes from 1000 to 1200 to 1000 to 1200 ...
Any idea what could cause this?
Thanks,
Shane Kullman
'98 RS Red
ScoobyDriver is offline   Reply With Quote
Old 02-02-2001, 09:33 AM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
Possible vacuum leak. Try checking you vacuum system with a vacuum guage or get a can of wd-40 or something similiar and spray around the engine compartment. If the engine revs or dies (cant remember which) then you have found a leak.
Have you tried resetting the ECU?
Old 02-02-2001, 10:23 AM   #3
ScoobyDriver
Member#: 195
2001 BH9
Post
Yup, tried reseting the ECU, and put in fresh 92 oct. I'll check the hoses and see what I see.
Old 02-02-2001, 10:48 AM   #4
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
durring the warm-up cylce the idle will do that. It's a normal thing. After a while it'll go back to normal.
Strepto is offline   Reply With Quote
Old 02-03-2001, 12:09 AM   #5
Keenan
Member#: 2277
2001 Impreza 2.5RS
Sedona Red Pearl
Post
Yep, it is normal. Let it run a few minutes and your idling RPMs will settle back down to 800 or so.
Keenan
Keenan is offline   Reply With Quote
Old 02-03-2001, 12:43 AM   #6
ScoobyDriver
Member#: 195
2001 BH9
Post
I must not have noticed it before, this being my 3rd winter with the car.
Thanks all,
Shane Kullman
'98 RS Red
Old 02-04-2001, 07:26 AM   #7
Freeskier
Member#: 3962
2001 F250 7.3L TD
2011 STi
Post
I had this happen and brought it to the dealer to find that it was a faulty idle intake valve. It took a week to get the part in and was covered by warranty and since then not a single problem.
Freeskier is offline   Reply With Quote
Old 02-04-2001, 07:53 PM   #8
BRN2RLY
Member#: 2696
2000 2.5 RS
Blue Ridge Pearl
Post
hey i have a question about my idle?
My car seems to idle at 400 or 350 rpm, is this normal or abnormally low.
Thanx
dave
BRN2RLY is offline   Reply With Quote
Rough idle, need new IAT? graphicsman Service & Maintenance 8 06-06-2010 12:11 PM
Surging/pulsing idle with AC on? Slalom RS Normally Aspirated Powertrain 8 09-11-2006 01:57 PM
Weird idle and car pulsing mogrl840 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 03-05-2006 12:24 PM
650cc injectors, how's your idle? (Minimum pulse width?) Really_Soaked Engine Management & Tuning 9 04-18-2005 11:03 PM
feedback pulse for idle Colin1955 Engine Management & Tuning 0 06-01-2004 07:45 PM
