Old 02-03-2001, 10:20 PM   #1
Garvinator
Member#: 3239
Post Centre diff on the Legacies and Imprezas..
Heyas.
I was just wondering what they use as the centre differential in these cars. Has it changed over the years?
do they use a Viscous Couple in all of them (auto and manual?)
cuz i think I read somewhere that the autos use electronically controlled clutches for the centre diff, while the manuals use a viscous couple.
thanks!
-G-
Garvinator is offline   Reply With Quote
Old 02-03-2001, 10:39 PM   #2
Garvinator
Member#: 3239
Post
oops
my bad finally found some stuff with the search on the board. http://www.i-club.com/ubb-files/Foru...ML/000451.html
and http://www.i-club.com/ubb-files/Foru...ML/000635.html
but then this moves my question ot what is used as a L-R diff for the front and rear?
-G-
Old 02-04-2001, 03:27 PM   #3
PunksRS
Guest
Member#:
Post
Garvinator,
You are correct. The manual transmission cars use a viscous coupling and the automatics do use an electronically controlled clutch pack that sends more power to the rear axle when it is needed.
Punk
Old 02-04-2001, 03:31 PM   #4
PunksRS
Guest
Member#:
Post
Garv,
Both the automatic and manual Imprezas (model year 2000 and newer) use a viscous coupling in the rear differential while the front diff is open. Theoretically, if you lost complete traction in the rear and one tire in the front you would get stuck! Some earlier Subarus had mechanical limited slips on the front such as my old 85 RX Turbo.
Punk
Swapping Diffs Between Legacy and Impreza subydude Transmission (AT/MT) & Driveline 11 12-24-2008 02:52 AM
Rear legacy and Impreza brakes the same??? Aspen Brakes, Steering & Suspension 14 10-07-2005 09:55 PM
Subaru Impreza Turbo suspension on the Legacy...!? Gustaf Legacy Forum 0 02-21-2005 11:34 AM
Stromung Midpipe: diff. part for Legacy vs. Impreza? snowone Normally Aspirated Powertrain 0 05-01-2004 02:35 AM
00+ Legacy and impreza suspension the same? skyliner33v Brakes, Steering & Suspension 3 07-07-2001 11:27 AM
