Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 07-02-2004, 06:27 AM   #1
Chaste Automotive
Vendor
Vendor Sales Rating: (0)
Member#: 44921
Default 2004 JDM STi HID Headlight Group Buy (only 2 available)
If you have gotten in a front end collision, you can replace your lights with HIDs with these. If you search NASIOC you can find out how to wire these up to your 2004-05 WRX. These lights are also a direct plug and play for the STi for those that do not want to bake their headlights to get that clear look and run the risk of making a mistake.
These are brigher than the USDM STI HIDs and do not have the cut off problem that was experienced with the HIDs on the older generation HIDs available for the 02-03s. The chrome in these is a smoked antrhacite. The JDM STI HIDs come clear from the factory so you do not have those annoying holes in your optical lenses from the removal of the amber lens as you do with the USDM STI HIDs.
THESE ARE NEW GENUINE SUBARU STi Parts from Japan, fully assembled with HIDs, burners, etc. We have two complete pairs.
Pricing is $1099 for each if we get two buyers. We sold our last two during our last group buy.
California residents add 8.25% sales tax.
kevin @ chasteauto.com
Chaste Automotive is offline
Old 07-02-2004, 09:01 AM   #2
Hank3
Member Sales Rating: (22)
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Pic not working
Hank3 is offline
Old 07-02-2004, 01:33 PM   #3
Chaste Automotive
Vendor
Member#: 44921
Fixed.
Old 07-02-2004, 03:48 PM   #4
DieselClown
Member Sales Rating: (27)
Member#: 36135
2005 WRX
if they ever go sub 900 im in. But until then, i can only wish. Nice headlights. So they're actually BRIGHTER than the 04 STi USDM HID??!! nice.
DieselClown is offline
Old 07-03-2004, 07:31 PM   #5
Chaste Automotive
Vendor
Member#: 44921
We can do a takeoff set of USDMs for that amount,
Old 07-05-2004, 12:42 PM   #6
Chaste Automotive
Vendor
Member#: 44921
We only need one more person!
Old 07-07-2004, 07:21 PM   #7
Chaste Automotive
Vendor
Member#: 44921
If you are going to clear your USDM headlights, think twice before you do:
http://forums.nasioc.com/forums/show...hreadid=590228
Besides that people have been reporting condensation if not sealed properly.
Buy the JDMs and Sell those USDMs!!!
Then you do not have to get mad when clearing your original headlights and it does not work.
JDMs RULE!
Old 07-07-2004, 09:24 PM   #8
DieselClown
Member#: 36135
2005 WRX
Lol, I was fearing that exact same thing. Anyway, I'm waiting on delivery of an 05 WRX, so the headlight is already darker, but the USDM take off is most likely the older ones where the reflector is chrome and the orange pieces are still intact correct?
Old 07-07-2004, 09:38 PM   #9
Whiplash
Member Sales Rating: (1)
Member#: 5589
'04 WRX
'99 Legacy Wagon
Oh my god those are sweet. Ive done a few searches and couldnt find very much as to how to wire these up in an 04 WRX. That is my main concern about buying these. I dont want to spend that kinda money and wire them up wrong. Can you point me in any direction? Thanks
Rich
Whiplash is offline
Old 07-08-2004, 12:42 PM   #10
Chaste Automotive
Vendor
Member#: 44921
Exactly. The 05 HIDs will go for a premium, so if you want the JDM look without the hassle of prying open your perfectly good pair of HIDs and risk not sealing them properly, this is a viable solution and you can probably sell yours for a bit of cash to offset the cost of these.
Rich
Two options
1) Go to http://www.chaiofangimports.com and spend $55 to get the piece they supply that will make the JDM STi HIDs plug and play.
Or
2) If you are a do it yourself kind of person, here are some instructions that others provided:
Originally posted by jac04
I installed the STi HID headlights into my 2004 WRX a few weeks back. The installation is very easy...It is very straight-forward. I assume that you know how to remove & replace the headlights, so I won't go into that. I also assume that you know how to use a soldering gun/heat shrink tubing, etc.
The standard disclaimer applies - This is what I did on my car. You should verify everything before performing this modification. I am not responsible for any damage or problems associated with this modification. Consult the service manual wiring diagrams WI-135 and WI-138.
By the way, the 2004 STi headlights are different from the standard WRX lights. The reflectors and bulb shields are different. I had a Catz HID kit on my car before switching to the STi lights. The Catz HIDs put out more light, but the beam pattern was not very good. The STi lights have an excellent beam pattern.
Here's what I did:
1) Disable the DRLs by disconnecting the DRL module behind the glove box. This is important.
2)On each headlight, there is a short pigtail lead that goes from the ballast to a black 2-prong plug. Remove these black plugs. You will then have one red and one black wire coming out of each ballast. The red are your positive leads and the black are the negative (ground) leads.
3) Solder a 18"-24" length of black wire onto each of the the existing black wires an put a ring terminal on the end of each.
4) LEFT HEADLIGHT (driver's side): Cut off the existing grey plug that plugged into your low beams and remove a few inches of the black protective tubing. You will have a yellow/red wire and a red/blue wire. Cap off the yellow/red wire - you will not be using it. Ensure that the red/blue wire is positive and is energized when the headlight switch is in the on position. Solder the red/blue wire to the red wire coming out of the ballast. Use heat shrink to weatherproof the connection. Take the black wire with the ring terminal on the end and attach it to the ground point next to the battery.
4) RIGHT HEADLIGHT (passenger's side): Cut off the existing grey plug that plugged into your low beams and remove a few inches of the black protective tubing. You will have a yellow/red wire and a blue/white wire. Cap off the yellow/red wire - you will not be using it. Ensure that the blue/white wire is positive and is energized when the headlight switch is in the on position. Solder the blue/white wire to the red wire coming out of the ballast. Use heat shrink to weatherproof the connection. Take the black wire with the ring terminal on the end and attach it to the ground point next to the air box.
5) Plug in the high beams and clearance/signal lights on both sides.
6) Properly aim the lights.
7) Enjoy your HID lights.
I hope this helps. Let me know if you have any questions.
-Jeff
Once installed, here is how level your HIDs:
Here is what is what you need to do to adjust/aim the HIDs once installed:
Locate the headlight beam leveler motor on the back of the headlight assembly. There will be a white plastic 8mm hex head protruding from the back of the motor assembly. Turn this hex to adjust the level of the beam. I believe that turning it clockwise raises the beam.
The Subaru manual states the following for adjustment:
1) Put the vehicle on a level surface
2) Verify tire inflation is correct
3) Make sure gas tank is full
4) Bounce vehicle to normalize the suspension
5) Be sure someone is in the driver's seat
6) Set the leveler switch to 0
7) Park the vehicle 10 feet from a vertical surface (wall).
8) With the vehicle 10 feet from the wall, the top of the beam cutoff should be 23.93 inches off the ground.
Kevin @ chasteauto.com
Old 07-09-2004, 09:58 PM   #11
Chaste Automotive
Vendor
Member#: 44921
Going once.
Old 07-12-2004, 02:01 PM   #12
ColonelSanders
Member#: 48086
How often do you get sets of the JDM HID projectors in? I'm buying an 05 WRX soon, but I don't want to commit to getting HIDs just yet. These will fit on the 05 model, correct? Will there be opportunities to buy these in the future, or is this kind of a one time only deal?
Thanks
ColonelSanders is offline
Old 07-13-2004, 02:36 PM   #13
Chaste Automotive
Vendor
Member#: 44921
These will fit the 05, but we do not expect to get these in again. If you are serious about HID, you may want to pick u this last set.
Old 07-13-2004, 09:04 PM   #14
Midwestrider
Member Sales Rating: (5)
Member#: 42955
2004 Bone Stock..
I am up for them?
Where do I sign up?
Do these come w/ the leveling switch and harness?
Midwestrider is offline
Old 07-13-2004, 09:41 PM   #15
Whiplash
Member#: 5589
'04 WRX
'99 Legacy Wagon
No..thats why he gave directions on how to wire and level them obviously.
Whiplash is offline
Old 07-14-2004, 08:58 PM   #16
Chaste Automotive
Vendor
Member#: 44921
Last one available! Going twice?
Old 07-19-2004, 04:42 PM   #17
Chaste Automotive
Vendor
Member#: 44921
Tentatively sold.
Closed Thread
FS: SoCal -- 04-05 STI and JDM STI HID Headlights COMPLETE! moddingbug Exterior/Styling 10 05-28-2010 01:47 AM
WTB 2004-2005 STi HID Headlights only Project Barnie Private 'Wanted' Classifieds 1 04-11-2009 02:19 PM
2004-2005 JDM STi HID Headlights Real Deal, very Rare. jcu1276 Private 'For Sale' Classifieds 28 04-21-2006 05:10 PM
STI LHD Headlights Group Buy - $875.00 Shipped Kickz107 Vendor 'Group Buy' Classifieds 586 11-26-2004 11:12 PM
2004 Impreza STi HID Headlights outcast Private 'For Sale' Classifieds 25 08-31-2004 01:52 PM
