Old 02-03-2001, 09:15 AM   #1
Shifter
Member#: 3728
Question Manual trans question
Need some advice.. I p/u my new car several days ago & have approx 250 miles on it. I went to check the fluid in the manual trans (engine off;car on flat surface) & the dip stick was completely dry. Now the owner's manuel says do not mix fluids. I have no idea, what was in it. At any rate, it took a full quart of fluid. I used Pennzoil Gearplus; 80w-90 GL-5. It seems to run OK.
Any idea why this would be a quart low on a new car?? I called the dealer & complained the salesman said they don't check that?? Did I do anything to screw it up??
Shifter is offline   Reply With Quote
Old 02-03-2001, 09:30 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
First, welcome to the club.
Second, now you have me worried! I'm going to have to go check mine now!
Eric
Eric SS is offline   Reply With Quote
Old 02-03-2001, 09:57 PM   #3
P.K. Motorsports
Member#: 1110
1999 RS
Post
You did nothing wrong. It's good that you caught it! The stuff you put in is fine, it will mix with the stock lube, but you might want to consider going synthetic.
P.K. Motorsports is offline   Reply With Quote
Old 02-04-2001, 09:19 AM   #4
vinman
Member#: 1425
2000 2.5RS
Post
Mine was low from the dealer too, not that low though. Check to make sure that the drain plug is not leaking. When I changed my trans fluid the drain plug came off REAL easy. I was suprised it didn't leak.
vinman is offline   Reply With Quote
Old 02-04-2001, 01:50 PM   #5
Shifter
Member#: 3728
Cool
Thanks for the responses..The last car I had (96 Probe) didn't have a dip stick on the trans so I wasn't familiar with what to put in it. However, I'm still under the impression the dealer should have checked the fluids when the vehicle was prepped. I thought that's what they get paid to do (or do they just wash it?). Fortunately I read the manual & decided to check it myself.
2002 WRX with Manual Trans cooling system parts question TampaWRX Private 'Wanted' Classifieds 0 11-16-2008 03:11 PM
question about driving manual trans.... Meat Supply Off-Topic 39 09-21-2008 07:09 PM
manual trans cruise control? trans swap concerns in 95 legacy legacy2003 Subaru Conversions 2 01-03-2004 05:33 PM
early legacy rs manual trans questions boogerwrx Legacy Forum 19 06-17-2002 04:53 AM
Who Rents Manual Trans Cars? Yotsuya Mid West Subaru Owners Club Forum -- MWSOC 7 12-05-2000 01:53 PM
Message Board Statistics All times are GMT -4. The time now is 06:41 PM.
