Old 07-02-2004, 08:30 AM   #1
Gadiel
UTEC Guru
Member#: 19290
2004 White STI
AEM Factory Trained Tuner
Default 449.9whp STI *UPDATE- 504whp and [email protected]*
Yesterday we retune our 2004 STI on the dyno.
Two weeks ago we run 2 cunsecutive pass of [email protected] but we want to improve our time.
We expect that this few additional horsepower help us to achieve at least 120mph and maybe 11.6sec
All this horspower is on stock block, head, clutch.
Good day for the STI are here.
Gadiel is offline   Reply With Quote
Old 07-02-2004, 08:35 AM   #2
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
What mods?
bikerboy is offline   Reply With Quote
Old 07-02-2004, 08:52 AM   #3
happasaiyan
Member#: 37731
wow, that added tuning REALLY helped out your midrange. peak is almost the same, but the area under the curve is much much better. nice numbers.
happasaiyan is offline   Reply With Quote
Old 07-02-2004, 10:54 AM   #4
AspWhtRex
Member#: 29393
2015 WRX
wrbp
wow nice numbers!!
AspWhtRex is online now   Reply With Quote
Old 07-02-2004, 11:36 AM   #5
gpatmac
Member#: 18446
2002 WRX wagon
psm
Originally posted by bikerboy
What mods?
gpatmac is offline   Reply With Quote
Old 07-02-2004, 11:54 AM   #6
Gadiel
UTEC Guru
Member#: 19290
2004 White STI
PE 850cc
Large Garret GT series Turbocharger
Greddy eo1
Utec
Exhaust
CAI
external wastegate
Fuel Pump
Custom made Front Mount Intercooler.
21.5psi
VP C16
Old 07-02-2004, 12:33 PM   #7
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
No kidding. What kind of changes did you make in the midrange. Either you had a suck-ass tune to begin with, or you upped the midrange boost. What happened? That is a huge improvement!
TypeC is offline   Reply With Quote
Old 07-02-2004, 12:56 PM   #8
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Good numbers for such low boost...
Clark
AZScoobie is offline   Reply With Quote
Old 07-02-2004, 12:58 PM   #9
Subaloo
Member#: 38217
2003 WRX
BLUE
Is this an Ultimate Racing kit?
Subaloo is offline   Reply With Quote
Old 07-02-2004, 02:25 PM   #10
Gadiel
UTEC Guru
Member#: 19290
2004 White STI
I adjust de start boost setting of the boost controller (greddy eo1).
The start boost is the setting that help us to prevent that the wastegate open earlier that we want.
When we adjust this setting was easy to gain boost on that range of the rpm.
Old 07-02-2004, 02:27 PM   #11
Gadiel
UTEC Guru
Member#: 19290
2004 White STI
Some of the parts are from the Ultimate stage 3 kit.
Old 07-02-2004, 06:28 PM   #12
wix
Member#: 29391
Very nice numbers! I can only imagine how much humidity there was on those runs too
wix is offline   Reply With Quote
Old 07-03-2004, 02:04 AM   #13
InfamousDX
Member#: 25413
Wow only 21 psi... Impressive
Old 07-03-2004, 02:42 AM   #14
Juan
Member#: 65540
STi Tuned by Gadiel
525 whp with U R kit
Thumbs up
Good job Gadiel. Congrats to you and the Big Valley team. Sigan para alante con el carrito!
I can't wait to see that car in the 1/4mile track again. With that power I know that is going to touch the 11.6 for sure.
Keep us updated!
Bala
Juan is offline   Reply With Quote
Old 07-03-2004, 10:02 AM   #15
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Need4Boost is offline   Reply With Quote
Old 07-03-2004, 01:20 PM   #16
MontrealSTi
Member#: 38045
Hi
Stupid question, but why are you running the greddy emanage and a UTEC, wouldn't the UTEC do everything you need?
Also, since most people wouldn't use C16 for daily use, how much HP do you think you would have on 93/4 octane?
PS Puerto Rico women are hot.
Thanks
MontrealSTi is offline   Reply With Quote
Old 07-03-2004, 01:49 PM   #17
nmyeti
Member#: 4980
EO1 = boost controller
nmyeti is offline   Reply With Quote
Old 07-04-2004, 01:28 AM   #18
wix
Member#: 29391
I think he means how come he is using the e01 to manage his boost instead of the UTEC.
Old 07-04-2004, 02:02 AM   #19
John Sever
Member#: 22866
2007 Victory
Vegas 8 Ball Black
this is my limited take on things....
The UTEc is good for controlling boost to a certain point. After that point(maybe 20+psi?) the UTec has a problem sustaining boost because of the stock solenoid that it is controlling. Or at least that what i've come to believe.
John Sever is offline   Reply With Quote
Old 07-04-2004, 07:54 AM   #20
turbo2nr
Visiting NASIOC Timeout
Member#: 63849
i thought that external wastegates do not use a solonoid, making an electronic controler obsolete? i thought external wastegate used an adj. screw to regulate the internal spring pressure on the valve? what type of wastegate are you using?
turbo2nr is offline   Reply With Quote
Old 07-04-2004, 07:57 AM   #21
turbo2nr
Member#: 63849
PE 850cc
Greddy eo1
Utec
Exhaust
CAI
external wastegate
Fuel Pump
21.5psi
VP C16
are you using a rotated mount turbo, to allow room to put the external waste gate in. i have no room to put an external waste gate un my up pipe.?
what turbo are you running and down pipe?
Old 07-04-2004, 06:23 PM   #22
BritneySpears
Member#: 29495
Chapter/Region: HIIC
NOT cobb stage 2
gosu micro
Maaaaaaankind! why is it that you guys can run 11's and I CAN'T???
Oh wait its becuase you have a garrett turbo the size of my head and supporting mods...and i dont.
BritneySpears is offline   Reply With Quote
Old 07-04-2004, 06:51 PM   #23
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
External wastegates still use a controller of some sort to vary the boost beyond the level the spring alone can sustain. You can also use the positive boost to force the gate shut aswell as not opening it. This allows a weak spring to be used but still hold high boost levels.
Paul
Pavlo is offline   Reply With Quote
Old 07-04-2004, 08:05 PM   #24
odin1
Member#: 29362
2008 2008 sti
stage 2
wOOt!
odin1 is offline   Reply With Quote
Old 07-04-2004, 10:09 PM   #25
turbo2nr
Member#: 63849
well, unless the wastegate has a line on both sides of the internal diaphram, that would be impossible! usually the spring is plenty strong enough to hold the valve shut and the positive boost pressure works against the spring to open the valve. adjustment is made by tightining or loosening the spring pressure. i have never seen an external wastegate that still uses a solonoid! please explain! you mean there are two sealed areas on each side of the diaphram? one would help valve to open with boost at a certian level(normal), and one on the back side of diaphram that could be used to help the spring stay closed. i don't think so.
