Old 11-20-2000, 06:12 AM   #1
SSLegacyGT
Member#: 2865
2006 Legacy 2.5i
Wagon, 5MT, Blue
Question Engine shudder/loss of power
I just returned from a trip to Vegas (from san diego). During that trip, my 97 Legacy GT (sedan) started acting up. When accelerating, I would experience a shuddering in the engine and dramatic loss of power between 1000-1500 rpms, but then the engine would seem to accelerate somewhat normally after that (sluggish but no shuddering). Small problem at first, but it has gotten worse. Any thoughts? I don't have any mods and I havent made in changes to the vehicle since I bought it.
SSLegacyGT is offline   Reply With Quote
Old 11-20-2000, 04:54 PM   #2
SSLegacyGT
Member#: 2865
2006 Legacy 2.5i
Wagon, 5MT, Blue
Thumbs up
Yeah that sounds like what I've got from what I've read. But, I'm confused on the fix. I read like 3 or 4 different fixes, none of which seemed like they were a 100% sure problem solver. I tried reseting ECU and that didnt work. Took it down to a dealer, they wanted $70 just to look at it. So I guess I'll try some of the stuff mentioned before heading their way. Thanks for the suggestion.
Old 11-21-2000, 12:10 AM   #3
vinman
Member#: 1425
2000 2.5RS
Post
I've seen posts about knock sensors and loss of power followed by normal acceleration. Try doing s search on knock sensors.
vinman is offline   Reply With Quote
Old 11-22-2000, 12:30 AM   #4
gumball
Member#: 1209
Post
Hey there, if the problem is w/ the ECU (its not the knock sensor, its how the ECU over-reacts to the signal), then the ECU re-set should definitely work. I had the exact same problem, and it was between 1800 & 2500 rpms, like a giant hiccup in the engine.
What happens (and the Subaru TSB confirms this) is that the faulty ECUs (the Subaru TSB reccommended replacing the ECU, not the knock sensor) over-react to the Knock Sensor signal and retard your timing. The retarded timing gets stuck in memory. So technically, an ECU re-set should clear it out and performance, at least momentarily, should be better.
If it isn't, then I'd also look into-
Ignition wires, fuel filter, air filter, clogged PCV valve etc...
and incidentally, I DID do the electronic fix (in line resistor, I believe) which mellows-out the signal from the piezoelectric mic on the knock sensor, and it works Great!
[This message has been edited by gumball (edited November 21, 2000).]
gumball is offline   Reply With Quote
Old 11-23-2000, 07:34 AM   #5
SSLegacyGT
Member#: 2865
2006 Legacy 2.5i
Wagon, 5MT, Blue
Post
Ok, thanks for the extra info, I think I will be getting thinline filter. Everythiing els you had mentioned I checked right off the bat. Thanks again...
Old 11-25-2000, 02:06 PM   #6
SSLegacyGT
Member#: 2865
2006 Legacy 2.5i
Wagon, 5MT, Blue
Angry
Ok, now the check engine light has come on. Normal with this ecu/knock sensor problem? Or would it be something else?
Old 11-25-2000, 09:56 PM   #7
kelley nelson
Member#: 135
Post
Has your car been serviced recently? Check all of your plug wire connections to make sure that none are loose or off completely. Is your gas cap on tightly?
[This message has been edited by kelley nelson (edited November 25, 2000).]
kelley nelson is offline   Reply With Quote
'07 WRX violent shudder and loss of power to rear end - axle? diff? DrnknZag Transmission (AT/MT) & Driveline 9 12-16-2009 11:35 PM
loss of power within 3 weeks of purchase KckAsX South East Region Forum 13 05-01-2002 04:13 PM
Recent loss of power Kachukaa General Forum Archive 0 01-15-2001 03:58 PM
Loss of power with Unorthodox pulley fellfrosch7 Car Audio, Video & Security 11 12-24-2000 10:09 PM
Loss of power and engine shudder SSLegacyGT Legacy Forum 12 11-23-2000 09:25 AM
