Old 07-02-2004, 06:38 PM   #1
surfer5567
Member#: 61199
2002 wrx wagon
wrb, s2, blouch 2.5, 6spd
Default what should i do?
well i was on my way home last night and i got ran off the road and ran into a curb. i have 5-zigen fighters w/ low pro tires and i have a pretty bad curb scrape on the rim and the tire has a cut along the side wall with a chunk hanging off it. it is not leaking air. my question is:
a. is there any way to repair the rim?
b. should i just cut the chunk off and use that tire like normal or should i replace that tire and the tire on the other side?
thanks for your help!!
bryan
surfer5567 is offline   Reply With Quote
Old 07-02-2004, 07:22 PM   #2
surfer5567
Member#: 61199
2002 wrx wagon
anyone?
Old 07-02-2004, 07:34 PM   #3
trd20
Member#: 58970
1999 Impreza 2.2rs
definitly replace the tire, and im pretty sure when you replace one you have to replace bothe fronts or both rears.
or have the tire shop shave the new tire
but if there is a chunk out of the tire it definitly has lost its integrity
trd20 is offline   Reply With Quote
Old 07-02-2004, 07:40 PM   #4
surfer5567
Member#: 61199
2002 wrx wagon
will do. now what about the wheel.
Old 07-02-2004, 09:57 PM   #5
roffle
Member#: 42251
uh oh
trumpet butt
see if you can find a single replacement - maybe even from 5zigen, wheel companies have pretty good service and they may sell you a replacement cheap
But judging by the amount of damage to the tire, I'd say the wheel might need replacing... put up pics if you can to get a more accurate response
roffle is offline   Reply With Quote
Old 07-02-2004, 11:18 PM   #6
surfer5567
Member#: 61199
2002 wrx wagon
the wheel is fine. trust me on that. there are no cracks, just a scraped up rim. thats all. not even that bad, i just want to know if i can fix it or not.
Old 07-03-2004, 01:12 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Are you SURE it isn't bent...???
Old 07-03-2004, 02:11 AM   #8
surfer5567
Member#: 61199
2002 wrx wagon
yes, very sure. checked it very carefully. all it is is scraped up. no chuncks or bends in it.
Old 07-03-2004, 04:13 AM   #9
se37wrx
Member#: 62279
2004 impreza wrx
java black
Default if you want to get the rim fixed
im sure it's mostly cosmetic damage?
check out www.bentrim.com
i'm ready to take my rims in for some cosmetic refinishing, at a fixed cost of 120 per wheel, it's better than replacing an entire rim!
se37wrx is offline   Reply With Quote
Old 07-03-2004, 12:19 PM   #10
surfer5567
Member#: 61199
2002 wrx wagon
thank you
02 WRX. 105K service. What should I do and how much should I pay? st000 Bay Area Impreza Club Forum -- BAIC 6 10-12-2008 05:34 AM
while installing my up pipe i did something bad. what is it and what should i do Yakshii Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-15-2008 02:13 AM
Trespassers... What are they doing? What should I do? markman Off-Topic 102 04-08-2008 02:42 PM
Help...what could be wrong & what should I do? ted dibiase Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-05-2006 10:55 PM
What should I do? What would you do? WiredWRX Southern California Impreza Club Forum -- SCIC 14 08-01-2004 07:08 PM
