Old 07-02-2004, 05:43 PM   #1
1fastrs
Member#: 60522
Default EJ20 vs EJ25
EJ20 or EJ25 on a 01 RS?
I've been reading on turboing the RS. A lot of people say, just do a engine swap because for one, its a lot safer, and two, its way cheaper. Ya I agree with those two things.
But I rather stick with my EJ25 and turbo it. The FAT and AVO kits say 4-6 psi is safe for the motor, as long as you don't go any higher than that. What kind of internal modifications do I need to make it safe to run higher boost? Cobb has a shortblock but they want almost $6,000.00 for it. I am just trying to make a list on what is needed to be boost safe.
I just plan to use my car as a everyday driving car. Maybe once every two months I will run it at the tracks. My goal is to get at least 285bhp.
1fastrs is offline   Reply With Quote
Old 07-02-2004, 05:56 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
ud need new internals pistons rods id do new valve springs
but u gotta remember for the small amount of torque ur gonna keep and the money ur gonna spend, u can get a wrx engine and get parts for it, run higher boost, and spend less
i chose an ej257 for those reasons
holds boost better
and is still a half liter bigger than a wrx engine
work being done myself w/ new springs was around 2gs but i got 350 for the shortblock so i was happy
Old 07-03-2004, 02:23 AM   #3
1fastrs
Member#: 60522
Ok, for those who are running high boost with their stock ej25 engines, what mods did you do to keep your engine from going to engine heaven?
Old 07-04-2004, 09:53 AM   #4
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
Engine managment is most important.
I've been running 12psi for ~3 years now, stock motor, daily driven. My engine is still running, but the tranny is another story. I'm on #4 now after breaking my KAAZ full dog box 2 weeks ago . Being safe and saving your motor is all about good tuning.
PunKidd is offline   Reply With Quote
Old 07-04-2004, 01:43 PM   #5
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
Stop being stubborn and do a wrx swap. Then from there 285whp is easy. 285bhp is not even worth mentioning.
thesmokingman is offline   Reply With Quote
Old 07-04-2004, 02:51 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
how did u break that on 12psi? 6k drops or something?
Old 07-06-2004, 03:01 PM   #7
PunKidd
Member#: 8533
2002 2.5 RS-T
I'm sure lots of red line clutch-less power shifting did not help.
The truth is the tranny should have been able to take that kind of abuse. It was designed to be used in off road racing, and to get slammed from one gear to the next. The parts are on their way back to Japan now, and there is a very good chance that they are going to warrantee the replacement of the parts. So at least it's not a total loss, just a pain in the butt.
Old 07-06-2004, 04:58 PM   #8
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
for me i went with EJ25 with
close dect with Cast Iron Liners, 8.5:1 piston, crank, rod, camshaft, valves, spring, and stage 3 bb turbo
but you might need $16-18k for this set up
ChAi is offline   Reply With Quote
Old 07-06-2004, 06:34 PM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
chai = money master
Old 07-06-2004, 06:39 PM   #10
1fastrs
Member#: 60522
can anyone give me 16-18k? anyways, if i had 18k, i would sell my rs and get a sti.
Old 07-06-2004, 09:07 PM   #11
Skully
Member#: 48990
98 Impreza RS
RBP
PunnKidd what engine management are you running? Link plus? or something else?
Skully is offline   Reply With Quote
Old 07-07-2004, 02:38 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
and then you'd need $6k/yr to insure it at the ripe age of 17
listen to these guys, don't try to half ass this, that's how things break, do a full swap you'll make 285 WHP and with the right turob you won't even realize that you have any kind of missing low end torque
Old 07-07-2004, 06:53 AM   #13
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
what jeremy said/me
Old 07-08-2004, 08:17 AM   #14
PunKidd
Member#: 8533
2002 2.5 RS-T
yeah, I'm running a Link +.
I'll be switching back to my stock ECU just a soon as I can find the map sensor limiter in the ECU program. Then we'll all have a great management solution, ECU reflashing I've already reflashed it for fuel and timing, just can't find that damn MAP sensor limiter.
ej20 vs. ej25 in wrx silverstreakwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-28-2005 03:26 AM
ej20 vs ej25 toebotypera Proven Power Bragging 4 01-15-2005 02:44 AM
Intake manifold EJ20 vs EJ25 ? Dr Ken Newbies & FAQs 1 08-28-2003 04:22 PM
EJ20 vs EJ25 (Turbo vs Turbo) MagicMT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-23-2001 11:52 AM
EJ20 vs. EJ25 Imprezanator Technical Forum Archive 4 09-17-2000 06:03 PM
