Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 07-02-2004, 11:36 PM   #1
WRXVII
Member#: 15854
VF34'd...
Default VF30 and supporting mods on Cobb stage 2 map... help
AP is scheduled to arrive on 12th of July. However, VF30 install is scheduled on 10th of July.
VF30 includes install of STi injectors and Walbro FP. What would happen if I were to drive the car with Cobb stage 2 map for several days if driven gently?
What's your thought on this?
WRXVII is offline   Reply With Quote
Old 07-07-2004, 10:15 PM   #2
BHawk
Member#: 61860
2004 WRX STi
Your going to have to get a customized map for the car to use the new injectors and fuel pump. As far as I know there is no map for the AP that works with a VF30 or bigger injectors and a fuel pump. Could be wrong though.
BHawk is offline   Reply With Quote
Old 07-07-2004, 11:18 PM   #3
BrianH
Bing user
Member#: 44383
they do have a map out supporting the vf30 & pinks. .
http://www.cobbtuning.com/wrx/accessport/
BrianH is offline   Reply With Quote
Old 07-08-2004, 08:56 PM   #4
tundra
Member#: 9290
02 Built 2.5L wrx
AKAIK many have used Cobb's base VF30 and fuel pump with good results.
But to answer your question, I think you'd be fine with the stage 2 map temporarily if you granny shifted and didn't go on boost much... if at all.
tundra is offline   Reply With Quote
Old 07-08-2004, 09:16 PM   #5
timman_24
Member#: 58722
I wouldn't risk it, even if you don't go into much boost you could risk engine damage. It's not worth it, just don't drive that car till you get EM. The new injectors alone would mess up the drivability pretty bad...
timman_24 is offline   Reply With Quote
09 WRX. Perrin stage 2 vs Cobb stage 2 map. Liquidr1 AccessPort 10 02-22-2010 10:05 PM
Just hitting 14 psi on cobb stage 2 map instead of 16psi wrxgeneration Newbies & FAQs 19 04-13-2008 07:30 PM
arc induction box on cobb stage 2 need help johnycakesg Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-03-2007 11:26 PM
Towing my Trailer and atv around on Cobb Stage 2?? wrxhunter General Community 4 02-06-2007 01:48 PM
Driving with VF39 on Cobb stage 2.5 map without JDM pinks... gopsu AccessPort 16 08-01-2006 11:50 PM
