Old 07-03-2004, 08:56 PM   #1
M3GTR
Member#: 21965
V-mounted 40R...what
Default Misfires up the wazoo
I just installed some 785cc injectors, and I am pulling misfire codes from all 4 cylinders. I am running a UTEC, the latest version with the fuel map scaled for the 785's. A wide band is on the way, but is it possible that I am still running way too rich? or does it have something to do with the ignition system. Any suggestions for possible solutions? Thanks.
-Nate
M3GTR is offline   Reply With Quote
Old 01-30-2005, 12:31 PM   #2
Casperwrx
Member#: 26179
2002 2.5 hybrid--aps
how did you end up fixing your problem--I have the same
Mike
Casperwrx is offline   Reply With Quote
Old 04-16-2005, 02:25 AM   #3
ngeren
Member#: 70562
2006 Jeep TJ
So far I think the answer is deal with it? I have these same horrible injectors, I wouldnt even wish them on Satan to tune.
ngeren is offline   Reply With Quote
Old 04-17-2005, 01:59 AM   #4
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
bad mouthing UR 785s?! no problems with mine, make sure your stock ecu is flashed with newest firmware
overdose is offline   Reply With Quote
Old 04-17-2005, 02:14 AM   #5
happasaiyan
Member#: 37731
to rid yourself of the misfires, before starting your car, put it to the "ON" position. wait about 5 seconds, then turn on.
remember, the CELs will only go away after about 3-5 starts after no misfires detected, so it might not seem to work at first.
also- probably want to check into getting new plugs. those might be fouled.
<- uses UR 785cc injectors, with one step colder plugs, with the "5 second rule", and has no misfires anymore.
happasaiyan is offline   Reply With Quote
Old 04-17-2005, 03:09 AM   #6
rewt
Member#: 60794
2007 Solstice GXP
the "5 second rule" worked for my random misfires as well, but i'm running modded stock injectors.
rewt is offline   Reply With Quote
Old 04-17-2005, 07:47 PM   #7
beefyib123
Member#: 55811
^^^ weird...i dont get them at start up i get them at random times...but NOT at start up. Will the 5 second rule help me too????
beefyib123 is offline   Reply With Quote
Old 04-18-2005, 07:02 AM   #8
happasaiyan
Member#: 37731
yes2345.
Help with greasing up the bushings kmper02 Newbies & FAQs 1 06-02-2010 03:52 PM
Misfiring up the A! turbowgnWHAT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-09-2007 12:19 AM
Whiteline out the Wazoo TB RACING Suspension/Brakes/Handling 38 01-10-2005 05:09 PM
Durango, CO sightings up the wazoo! Evil-Mastermind General Forum Archive 7 10-10-2000 09:18 PM
