Old 07-04-2004, 10:41 AM   #1
drb5
Member#: 46061
Question what tuners to see about 2.2 shortblock.....
looking to find a tuner who can supply a 2.2 shortblock sleeved with uprated internals to 2 litres, does anyone know anywhere other than axis, magnus and crawford?
thanks
drb5 is offline   Reply With Quote
Old 07-09-2004, 01:06 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
you've mentioned the ones that come to mind. PM me is you are interested in buying the "core" engine to do this build. I have one sitting in my garage and it will run you less to have this one built than to buy one from one of those guys already assembled...
Old 07-09-2004, 02:18 PM   #3
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
I would go with crawford, axis has a nice waiting list and magnus has a longer waiting list then cobbs. Not good.
Old 07-10-2004, 03:41 AM   #4
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
www.crawfordperformance.com
MJU1983 is offline   Reply With Quote
Old 07-16-2004, 11:52 AM   #5
singsing
Member#: 36991
2003 Liberty B4
blue
arent you with axis mike?
singsing is offline   Reply With Quote
Old 08-02-2004, 06:08 AM   #6
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Not anymore....I hear he is a freelance cabaret dancer....
mr2guru is offline   Reply With Quote
Old 08-05-2004, 04:50 PM   #7
mafiamotorsports
Member#: 67180
1996 OBS(GFC)
94 Mitsu Diamante LS
Outback Sport Sleeved?
What do you mean by sleeved? I am new to the boxer engines. Came over from VW's. So could you elaborate on it? I was told the 2.2 was no good for tuning?
mafiamotorsports is offline   Reply With Quote
Old 08-05-2004, 05:44 PM   #8
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Blocks are aluminum...so they are sleeved with Iron liners in the cyl.
Actually the 2.2 (sans cast pistons) is probably the strongest factory subaru block.
Old 08-05-2004, 05:47 PM   #9
MJU1983
Member#: 14364
I work for Citigroup/Citibank.
Old 08-06-2004, 11:47 AM   #10
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Used to work for Ron..
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-07-2004, 06:33 PM   #11
MJU1983
Member#: 14364
Jorge (RiftsWRX)
www.ProjectWRX.com
You are correct, he still owes me money...
Old 08-19-2004, 03:06 PM   #12
NorthWesternMIScooby
Member#: 68560
1992 Legay Touring
What kinda performance mods can be done to a 2.2 with stock internals?
NorthWesternMIScooby is offline   Reply With Quote
Old 08-24-2004, 02:42 AM   #13
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Mods to a 2.2 with stock internals? I have about 100 miles on a 10 lbs of boost via supercharger on a 1990 2.2 wagon! Lets see how long it lasts! Then give me a call!
Actually, it supposedly depends on the year of the 2.2. 1990-94 are stronger than the other 2.2s. Or so I hear. But then again, I am running 10 lbs of boost on a 1990 2.2 and it is great. And when your try this on 2.5 rs motor, they blow up. Which would you choose?
Old 08-25-2004, 06:17 PM   #14
Boxologist
Member#: 21118
on the legacy turbo block, on stock, its reported to run high PSI with an intercooler. more than +2 atmopheres. remember, that block runs a very low compression, so u have to be spooled up to get that car moving period.
i will be having a used block that i bought overhauled so i can up the compression to almost JDM spec so i can have some torque and need the boost later on.
Boxologist is offline   Reply With Quote
Old 09-07-2004, 02:02 AM   #15
BoostdScubaru
Member#: 42188
can i find higher compression pistons for this motor... or use WRX pistons?
also with WRX heads what is the compression ratio... ?
WRX heads and 1.1 mm metal head gasket Compression Ratio??
BoostdScubaru is offline   Reply With Quote
Old 09-08-2004, 04:14 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
No,
You cannot use WRX pistons. They don't have enough bore. AS for your othe questions, go over to the conversions forum and look for a thread titled,"this should be the last EJ22T thread". It has links to discussions that answer all of these questions and have the math.
reddevil,
Methinks you are confused. We are discussing the EJ22T closed deck turbo block. You are talking about a plain jane NA EJ22 block. But your remarks about it being stronger than new EJ22's are correct, just not relevant to this discussion. EJ22T's can hold 25+psi of boost.
Old 09-08-2004, 05:55 PM   #17
BoostdScubaru
Member#: 42188
is the EJ22T the shortblock i can buy new for $2000 from subaruWRXparts.com
and i just wanted to know what compression is for the WRX heads being on the stock shortblock, with 1.1 mm metal head gaskets...
Old 09-09-2004, 06:32 AM   #18
totoherbs
Member#: 7321
.... 122 IggPoints
On wrx heads its something like 7.7 to 1. Here is the thread Matt was talking about. http://forums.nasioc.com/forums/show...highlight=ej22
Old 09-09-2004, 08:57 PM   #19
BoostdScubaru
Member#: 42188
the 2.2T block goes for $1529 + shipping at subaruparts.com
part # is 10103AA310
Old 09-09-2004, 11:53 PM   #20
BoostdScubaru
Member#: 42188
also what ecu, and what harness do i need...
can i use pretty much everything just like the WRX motor...
Old 09-10-2004, 01:13 AM   #21
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
there have been like 4 really good threads in differenet forums. try searching in the conversions forum, the 2.0 forum and the afi forum.
subiekid is offline   Reply With Quote
Old 09-10-2004, 08:28 AM   #22
totoherbs
Member#: 7321
.... 122 IggPoints
That is with out the gaskets. The ecu depends on what your going to use... but ya a wrx ecu would work. If it was reflashed.
Driving across country (D.C. to LA). What/where to see/stay? rex n effect Off-Topic 19 01-18-2008 03:14 PM
Going to Philly for a weekend to see the Red Sox play, what ELSE to see while there? 03WRXMA Off-Topic 51 06-08-2005 05:52 PM
Things you never wanted to see about yourself on CNN: rogue Off-Topic 7 01-10-2005 04:45 PM
question about what i should do about these 2 girls skylineR34 Off-Topic 28 07-23-2003 07:44 AM
