Old 07-04-2004, 11:09 AM   #1
BIGSKYWRX
Member#: 7958
09 GH B+
Default How EXACTLY does the STi gain it's ~ 1 degree of caster
Does anyone know exactly how they gained the additional degree? I see the rear transverse bushings have different part#'s
WRX (R) 20201FA070
(L) 20201FE080
STi (R) 20204FE110
(L) 20204FE120
Are the metal portion of the bushings thicker on one side ala Whiteline ALK (I don't think so as there are no spacers on the subframe- as needed w/ the ALK)?
Are the bushing holes offset? Is the entire cross member mounted differently to allow for more caster? Is the black piece that holds the rear bushing a different shape than the one that came w/ the v7 aluminum arms?
Inquiring minds want to know.
Thanks
Big Sky
Old 07-04-2004, 01:04 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I remember reading in a post somewhere that it was a combination of things but I believe most of it is due to the transverse link(aka 'control arm') being dimensionally a bit different in such a way as to add caster, and this was one of the lesser known benefits of the aluminum 'control arms'.
Whether this is, indeed, factual or not, I don't know.
Old 07-04-2004, 01:41 PM   #3
BIGSKYWRX
Member#: 7958
09 GH B+
The actual v8 arms are 20202FE300 and 310, the part # for v7 arms are a ST part# and include the entire assembly- both arms, rear bushings/ball joint etc. So I can't tell if the arms themselves are the same.
It's possible the actual arms are different, but it would be cheaper to reuse the same arms and tweak the rear bushing some how.
If it's just the rear bushing, might be a good option for guys running the v7 aluminum arms wanting another degree of caster.
Big Sky
Old 07-04-2004, 01:50 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
...if I wanted even more caster, I'd do the Whiteline bushes anyway, if the stock ones looked like they weren't offset.
Old 07-04-2004, 02:48 PM   #5
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
someone I know pretty familiar with subarus said its the control arms. The v7 and v8 ones are different because the v8 ones have more caster.
Peter
petawabit is offline   Reply With Quote
Old 07-04-2004, 02:53 PM   #6
BIGSKYWRX
Member#: 7958
09 GH B+
Peter
Interesting- I'd love to see a set side by side and see what they did (if indeed the arms are different)
Old 07-04-2004, 05:45 PM   #7
igalwrx
Member#: 13643
'02 WRX Sdn WRB
'05 Leg GT Ltd Wgn Black
The V8 sti's wheelbase is 100" versus, IIRC 99.4 for the V7. The extra .6 inches is due to the control arms which give the additional castor. Check out this thread
igalwrx is offline   Reply With Quote
Old 07-04-2004, 06:02 PM   #8
BIGSKYWRX
Member#: 7958
09 GH B+
Thanks- read that thread, still doesn't answer how the increased caster (and resultant whel base increase) was had. If it's the rear bushings vs the actual arm, it could be quite a boon for those w/ aluminum arms.
Big Sky
Old 07-04-2004, 06:25 PM   #9
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
bigsky-my friend was telling me the additional caster comes from the control arm itself, not from the bushing. Is it caster or castor? I don't want to be spelling it wrong this whole time. With kits such as the perrin and whiteline bits, I think it adds even more caster/castor to STi's.
Peter
OT-whats with the change bigsky? why did you leave the bugeyes for the wagon? :-) just wondering
Old 07-04-2004, 08:32 PM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
If it's the arms, I'd love to see what they've changed, from pics they look the same- but tough to get detail out of a pic.
Caster- castor = beaver or castor bean
I burnt the exhaust valves in my sedan, when I took it to the dealer- they made a deal I couldn't refuse - besides ever since my wife had founf out that the WRX was available as a wagon- that's what she really wanted.
Big Sky
Old 07-04-2004, 09:16 PM   #11
igalwrx
Member#: 13643
'02 WRX Sdn WRB
Big Sky
Ok smartypants read this thread , near the bottom of it you'll see rallispec's response to my questions about this "igalwrx: Since we've never held this part in our hands, it is impossible to say if it's a straight swap. However, it is uber-likely that they do bolt right on since the rear bushings are interchangeble. However (ver.2), the Spec.C and USDM STi share a rear bushing that doesn't have the same part# as all the other car's rear bushings, yet they are physically interchangeble. Confused? The jist is: if you're going to use these arms, also use the rear bushings that go along with them to aleviate any chance of wierd handling."
Old 07-04-2004, 10:06 PM   #12
BHawk
Member#: 61860
2004 WRX STi
I am relatively new to the WRX world.
Is the Caster on this car not adjustable by any other means than by changing a suspension part out for a differen't one? All my previous cars have had adj caster. Maybe that's abnormal, but I was hoping this would be the same way. I was going to get my STi re-aligned with slightly more neg caster and little more neg camber front with a proportionally smaller neg camber increase in the rear. However, if I can't adjust the caster I might just wait.
BHawk is offline   Reply With Quote
Old 07-04-2004, 10:11 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
Increasing positive static caster in the Impreza is your friend
And the only way to change it is by changing parts, or hitting something...not recommended
Old 07-04-2004, 11:17 PM   #14
BIGSKYWRX
Member#: 7958
09 GH B+
igalwrx- thanks for searching , but still doesn't answer the question. It has unique rear bushings ie as I posted above and they've never had one in their hands- I most have been from Missouri in a past life . I originally talked to Dave at rallispec, many moons ago when the revision c's were first coming out- he thought it was the rear bushings that gave the additional caster, he also thought the black piece that bolts onto the arm (don't know what to call the little bastard) was different as well.
BHawk- you have no worries, you've got the STi and 4.5 degrees of caster
Big Sky
How exactly does the Taxtrix Cable/Ecutune work? Dont Try To Run Newbies & FAQs 67 03-25-2009 06:36 PM
so tell me, how exactly does the president have control over the economy? [27] Political Playground 27 11-13-2008 12:33 PM
how much does the sti 6 speed transmission cost? awdguy Transmission (AT/MT) & Driveline 2 06-12-2004 11:00 PM
How exactly does the STi EBD/ABS work? skregg STi Forum Archive 34 02-20-2003 11:27 AM
WRX Turbo - How exactly does the Turbo work? rdrandal Newbies & FAQs 5 11-02-2001 11:24 PM
