Old 07-04-2004, 03:08 PM   #1
orthikon
Member#: 43395
04 WRX mods:
Still fixing the driver
Default A/X pressure for 215/45/16 Azenis
I was wondering if anyone can give me suggestions to tire pressures for autocross on 215/45/16 Azenis sports
I am currently running 36 f/r and it seems to be fine (wear is above the arrows) but this was just on on/off ramps, where the loads are nowhere near that of autocross.
orthikon is offline   Reply With Quote
Old 07-04-2004, 03:27 PM   #2
Swano
Member#: 19114
2002 2.5TS
Blue Ridge
I run 40 Front /41 or 42 rear. These are hot pressure, measure it after your first run.
This is the best pressure I found for car rotation.
I'm running with 205-50-15 wich have a little more sidewall then your 215-45-16 so you might be able to run 1 or 2 psi less then me.
Good luck!
Phil =)
Swano is offline   Reply With Quote
Old 07-05-2004, 12:54 PM   #3
GRoceryTurbo
Member#: 9407
02 WRX
platinum silver
I run the same pressure as Swano, but use 215/45/16's.
GRoceryTurbo is offline   Reply With Quote
Old 07-06-2004, 10:26 PM   #4
orthikon
Member#: 43395
04 WRX mods:
given pressures noted.
with 36 f/r cold my tires would heat up to 40 f/r after a canyon run and even a one freeway on/off ramp. these tires heat up fast!
GRoceryTurbo: are those your autocross pressures?
FS: 215/45/16 Azenis used for one event baileypicks24 South East Region Forum 3 05-03-2005 06:10 PM
FS: '00 RS rims with 215/45/16 Azenis Thug Private 'For Sale' Classifieds 20 06-02-2004 10:27 PM
FS: '00 RS rims with 215/45/16 Azenis $600 Thug New England Impreza Club Forum -- NESIC 10 07-07-2003 09:25 PM
225/45/16 712s vs. 215/45/16 Azenis RebelINS Brakes, Steering & Suspension 9 04-12-2003 12:26 PM
Anyone have 215/45-16 Azenis in stock? Branwell Brakes, Steering & Suspension 3 04-25-2002 03:51 PM
