Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-30-2000, 03:09 PM   #1
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
I've ended up doing it to every Subaru I've owned (a BRAT, a Loyale RX, and and Impreza L) at one point or another (because of rattles) with no problems. I haven't touched the shields on the RS yet.
Brian
http://members.nbci.com/_XMCM/northu...reza/index.htm
Old 10-31-2000, 12:47 AM   #2
legacyGT00
Member#: 2052
Question Exhaust heat shielding...
Can't really figure out if this goes here or not, but I don't know where else to put it.
Has anybody removed the heat sheilding surrounding the exhaust? I'm hunting to shed all the weight I can in a rally RS.
legacyGT00 is offline   Reply With Quote
Old 10-31-2000, 01:28 PM   #3
Buckbomb
Member#: 2573
Post
Would you be willing to post it's weight when you do? I'm a bit curiouse myself.( If it isn't to much trouble)
Buckbomb is offline   Reply With Quote
Old 10-31-2000, 02:14 PM   #4
P.K. Motorsports
Member#: 1110
1999 RS
Post
I removed it from the second cat back. It is not very heavy, a couple of pounds perhaps. The big piece over the muffler produced an irritating rattle with my Strohmung.
P.K. Motorsports is offline   Reply With Quote
Old 10-31-2000, 02:37 PM   #5
Kachukaa
Member#: 2527
1997 Legacy 2.5GT
Quicksilver Metallic
Post
I removed it on my Legacy GT because of rattling. After lots of miles and road and rally racing I have had no troubles.
Kachukaa is offline   Reply With Quote
Old 11-01-2000, 12:56 AM   #6
legacyGT00
Member#: 2052
Post
Thanks Brian. Probably take it all out in a couple weeks. With no interior left, I'm wondering how hot the floor will get.
Old 11-01-2000, 07:26 AM   #7
legacyGT00
Member#: 2052
Post
While I am trying to shave off every possible extra pound, the heat sheild is also in the way of stuff.
Old 11-02-2000, 12:12 AM   #8
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Post
I did surgery on Saturday. Just get under the car with a 10mm and 9mm sockets and closed wrenches to unscrew everything. Then use a locking wrench to bend the lips on the edges of the heat shields to a 90° angle. Lastly, use a narrow pry bar to wedge apart the upper and lower portions of the heat shield. It's a pain in the ass to get started but once it starts splitting it takes about 2 minutes to pry off.
Make sure to jack the car up and use jackstands. Also, you'll be applying a lot of torque to the pipes to pry off the shields so be careful...don't want to bend anything. But yeah, I was sick of the rattles so I just yanked them off.
Trunkmonkey is here! There is no cone...
Sean Sosik-Hamor < [email protected] >
Epinions Automotive Reviews by `Sean
47STS MY98 Subaru Impreza Outback Sport
Sean is offline   Reply With Quote
Old 11-02-2000, 11:19 AM   #9
legacyGT00
Member#: 2052
Post
Maybe I'll wait til I upgrade the exhaust. Probably be easier to get the heat shielding off without the exhaust, right? I'm going to be doing some more work in a couple weeks, I'll take a look at it then.
Old 11-02-2000, 11:39 AM   #10
samurai
Member#: 696
2005 WRX STi
Post
The heat shield around the exhaust piping is there so that there is minimal heat radiating to the bottom part of the chassis. I don't know what type of material is covering the metal chassis, but the heat shields are there in order to protect that area from being "burnt to a crisp" (for lack of a better term). You can try removing the shields, but beware of what I told you if you smell something burning.
Tim
samurai is offline   Reply With Quote
Old 11-02-2000, 11:59 AM   #11
Liquid Calm
Member#: 2744
2005 STi
WRB/Gold
Post
I took off just the shielding off by the Muffler when I had the cat back put on less rattle....have had it off since Apr 99 no probs.
Liquid Calm is offline   Reply With Quote
Old 11-03-2000, 07:07 AM   #12
legacyGT00
Member#: 2052
Post
It seems that several people have been running without it with no problems. What about using insulating exhaust tape? That would help contain the heat to withing the exhaust piping. Is it better to have the exhaust radiating heat? Would containing the heat cause poor flow?
Old 11-03-2000, 03:19 PM   #13
samurai
Member#: 696
2005 WRX STi
Post
I thought they sold exhaust header blankets. What you could do is maybe buy that and wrap that around the exhaust.
Tim
Old 09-06-2005, 08:04 PM   #14
tfisher311
Member#: 94517
1997 Legacy GT
Stock 1997 Legacy GT sedan.
I have been removing heat shields since I bought this car a few weeks ago. It has "almost" stopped rattling. I started with the first 2 shields on the header pipes directly out of the engine since they were clearly rusted loose. That helped but I still had a rattle under moderate acceleration. I continued removing the longer shields on the 2 pipes before entering the Y junction. I also removed the shield that covers the Y junction. Now most all rattles are gone except for the rare rattle under moderate acceleration under load.
I'm reluctant to remove the shields on the resonator and cat conv for 2 reasons.
1. Once I am able to undo the fasteners and drop the bottom shield, will I be able to slip the top shield out between the exhaust and the body ?
2. Will the absence of these shields allow excessive heat to come in close contact with the body ?
Has anyone removed these 2 shields without trouble or concequence ?
tfisher311 is offline   Reply With Quote
Lot of part vf39 injector cf exhaust heat shield cusco heat shield Ect ppericfe Tri-State Area Private Classifieds 14 02-28-2009 08:08 AM
(NYC)Lot of part vf39 injector cf exhaust heat shield cusco heat shield Ect ppericfe Engine/Power/Exhaust 13 01-07-2009 11:27 PM
Removal of exhaust heat shields, bad or no problem? lag Legacy Forum 28 10-28-2003 09:00 AM
Installed New Exhaust/Heat shield remove? willow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-11-2002 11:01 PM
