Old 07-04-2004, 09:31 PM   #1
Slatts
Member#: 21793
03 WRX 18G 6spd
04 V10 EXCURSION LTD
Default Is anyone running the STI ecu in the Forester XT with the stock turbo ?
Is anyone running the STI ecu in the Forester XT with the stock turbo ? I am wondering how it runs? Is it rich due to the loss of cfm @ 16psi on the stock turbo versus the VF39? Has anyone ran Delta Dash on this setup to get an idea how ideal it's running? I would like to see if it's a viable option to pick up a used ecu, and drop it in, rather than reflash or Cobb. My planned mods with the STI ecu would be uppipe, 3" TBE, USDM STI ic, and K&N filter with silencer removed.
I asked this in the Forester Forum, and haven't got much response, so some cross posting it is! Feel free to delete one if you must.
Any feedback would be welcomed.
Matt
Slatts is offline   Reply With Quote
Old 07-05-2004, 02:28 PM   #2
VSB XT
Member#: 45034
12' WRX Limited
That dark grey color
With the stock turbo you may as well get a reflash for all the safety features. Especially with those mods. A guy on the Forester forum used the STI ecu w/ the STI turbo) and it ran but there are still other differences between the two engines. And those using the STI end up needing a reflash anyway to make it all work right. Play it safe, because you can, plenty of us XT owners were guinea pigs for what works, just use that to your advantage.
VSB XT is offline   Reply With Quote
Old 07-05-2004, 04:06 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no
get a reflash
it might start and run but ... its going to be way out of tune
the cams will also make a difference
get a cobb stage 2 and call it good
for 425 its not that much more expensive than as sti ecu
Is anyone running a rotated kit with a blow thru and just a filter on the turbo? 03clipsegts Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-11-2007 08:11 PM
running 87 octane in a forester xt turbo.. is it ok? ruppenduro Forester Forum 21 01-02-2007 09:50 PM
STI ecu in XT. stock turbo ? Slatts Forester Forum 11 07-12-2004 12:11 AM
does the sti intake manifold make any power with the stock turbo? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-06-2003 12:33 AM
Is anyone running a six speed in a GC, GM body car? RebelINS Transmission (AT/MT) & Driveline 24 01-20-2003 02:19 AM
