Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 07-05-2004, 12:05 AM   #1
wei
Member#: 3719
Angry avo kit help!!!
anyone runing avo kit on99' 2.5rs?
just installed the avo kit today on my 99'rs,but the kit is for 2000 rs,i follow Installation instructions to connect LINK ecu wire to the stock ecu,then i start the engine ,lots of white smoke came out .when i use stock ecu plugs s-afc to running the engine, everythine seem ok,but hear someting like knocking from engine.
i dont know avo kit will work with a-sfc or not.anyone have idea??
thank u!
wei
wei is offline   Reply With Quote
Old 07-05-2004, 09:37 AM   #2
avoturbo
Member#: 21292
2002 WRX STi
Default Re: avo kit help!!!
thank u!
wei
The supplied LINK ECU will do the job of the S-AFC, you should not need the S-AFC any more.
avoturbo is offline   Reply With Quote
Old 07-05-2004, 11:43 AM   #3
Aphex
Member#: 146
'05 Genesis Sedan
if the link harness is for the 2000, then that could be your problem..... I _believe_ that the pinouts are not the same between the '99 and '00. And yes, there is absolutely no point in hooking up the S-AFC with the link.
Aphex is offline   Reply With Quote
Old 07-05-2004, 01:02 PM   #4
SubyBean
Member#: 4367
1999 IMPREZA 2.5RS
Black :-( with dings
yes the pin outs for the 99rs are different from the 00's go to ravensblade-impreza and find the pinouts for the 99rs.
Brian
SubyBean is offline   Reply With Quote
Old 07-08-2004, 09:58 AM   #5
Rallitek.com
Member#: 34814
08 WRX
Lightning Red
Sounds like the right answers. Call us if you need any help.
Sean Sexton
www.rallitek.com
503.546.9209
Rallitek.com is offline   Reply With Quote
Installed my AVO kit today and have a few questions Tats Normally Aspirated with bolt-on Forced Induction Powertrain 53 08-30-2005 08:34 PM
More help needed: Link wiring on AVO kit on a MY00 kgb Normally Aspirated with bolt-on Forced Induction Powertrain 11 02-01-2005 08:47 PM
My AVO kit gets installed this week!! svxr8dr Normally Aspirated with bolt-on Forced Induction Powertrain 31 08-25-2003 06:48 PM
Ludespeed Stage III VS Forced Air Tech Stage III VS AVO kit Blu25RS02 Normally Aspirated with bolt-on Forced Induction Powertrain 10 07-23-2003 10:56 AM
Installing AVO Kit and a few questions... Tats Normally Aspirated with bolt-on Forced Induction Powertrain 3 03-13-2003 07:36 AM
