Old 07-05-2004, 01:26 AM   #1
valley wagon
Member#: 58595
2015 STI
CWP
Default wheel weight vs performance
I want a set of volk gt-c on 18's but I found out that they weigh 22 pounds! I know that it'll affect my performance but by how much? Please don't say alot or something like that.
valley wagon is offline   Reply With Quote
Old 07-05-2004, 01:56 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The lighter the better....22 pound wheels are a lot....I noticed the difference immediatly when I put new tires on that weighed 3 pounds each more than the ones they replaced.
I'll go back to a light tire next time.
I'd try to stay under 20 pounds/wheel
Old 07-05-2004, 12:30 PM   #3
Zack
Member#: 41126
2000 Miata
Emrald Mica
I didn't think too much about un-sprung weight a while back, but since then I've learned more about suspension and also seen how my own car takes bumps with completely worn out shocks, and I can safely say it's a big deal. See, he whole point of the suspention is to keep the tires on the ground at all times, right? So if the wheels, tires. brakes, controll arms, ect. are heavy, it's harder for the suspention to push it all back down to the ground when the wheel gets jounced upward by a bump. Look at my car, I go around a medium turn at 40-50 mph on rough pavement and my rear end can move up to 7 or so inches just by bouncing off the pavement. Some people I think call it wheel studder.
Also lighter wheels means less rotating mass, so that helps much more than weight reduction of static parts for exeleration.
Zack is offline   Reply With Quote
Old 07-05-2004, 01:29 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
Which is why I deceided on SSR Comps and light tires.
My 17" SSR's with light tires weigh LESS than the stock wheel/tire combo. It REALLY does make a difference.
Old 07-05-2004, 07:51 PM   #5
Len
Member#: 39937
2011 328i 6MT
LMB
The real effect of heavier wheels can be all very subjective, and it also depends on how demanding a driver you are. But in terms of acceleration, if you go from stock wheels (16.5 lbs) to those that you mentioned plus fatter tires, it will be like adding (roughly) 50~ 70lbs chassis weight. That's about 2 % of the total weight, and you'll be about that much slower. Then there's the unsprung weight factor which might be more apparent since the wheels/tires account for a large portion of the total unsprung weight.
Do a search on "rotational inertia" and you'll find a few informative threads.
Len is offline   Reply With Quote
Wheel weight vs. acceleration test question gtguy Tire & Wheel 90 10-15-2011 03:44 PM
Wheels width vs. wheel weight on street car CR22 Tire & Wheel 34 12-10-2008 12:33 PM
Wheel weight vs. Wheel HP/Tq?? GreenMarine South East Region Forum 7 05-15-2008 05:44 PM
Wheel Weight Vs. Wheel Width ... What's more important ... makofoto Motorsports 19 09-13-2004 12:26 PM
99' wheel weight vs. 00' wheel weight? Dolphin Overton Brakes, Steering & Suspension 4 06-26-2001 04:21 PM
