Old 11-01-2000, 05:48 PM   #1
Daios
Member#: 1111
2000 2.5RS Sedan
BRP 4EAT
Post AT oil cooler (Hayden 403)
Ok I just got the AT oil cooler from pepboys. For those of you that have this, did you cut the one hose in half? Stick one that goes from the radiator - cooler and the other one from cooler to the coupling to original oil return? is that how it is? Instead of using the coupling directly to the radiator, use it to connect 2 hoses? Also (just to make sure) is the return line the one on all the way at the bottom on the passenger side? TIA
-Daios
MY00 BRP SeDan
Daios is offline   Reply With Quote
Old 11-02-2000, 02:31 PM   #2
Daios
Member#: 1111
2000 2.5RS Sedan
BRP 4EAT
Post
Bump!
Anyone? I want to do this in a couple mins. Well I'll see what happens.
-Daios
Old 11-02-2000, 05:27 PM   #3
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Post
redobs is offline   Reply With Quote
Old 11-02-2000, 07:46 PM   #4
Daios
Member#: 1111
2000 2.5RS Sedan
BRP 4EAT
Post
Thanks. Well I just finished installing everything and everything looks like its ok. I used the coupling that came w/ the kit to connect the hose from the cooler to the hose that goes to the tranny. Is that what everyone else did? I also just stuck the zip post through the AC condenser only and not through the AC and radiator. (I didn't want to take out the fans and saved time).
-Daios
Old 11-02-2000, 08:16 PM   #5
ivbdn
Member#: 2736
2001 Impreza 2.5RS
Post
How much was the cooler? I'm thinking of doing this mod as well.
ivbdn is offline   Reply With Quote
Old 11-02-2000, 10:39 PM   #6
Daios
Member#: 1111
2000 2.5RS Sedan
BRP 4EAT
Post
$39 from pepboys. I'm thinking of getting the gauge that tells the temp of the oil. I think its $35 for the gauge, and its the same makers of the cooler. Its hanging near the coolers.
-Daios
Old 11-03-2000, 05:05 AM   #7
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Post
I was hoping to ask you what the temperature difference is that you noticed once you installed the cooler. When you get the gauge, please post the temps on your car at various loads and speeds. I don't have any room for any more gauges so I didn't buy one.
I've had it installed for for a few weeks now and it inspires confidence to say the least.
Kevin Thomas is offline   Reply With Quote
FS : Oil Cooler Kit Power6 Engine/Power/Exhaust 5 06-25-2010 12:42 PM
I'm at a dead-end for an oil cooler on my '05 STI, with FMIC kc jazz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 02-16-2009 06:32 PM
Hayden 403 Tranny Cooler BENSREX Private 'For Sale' Classifieds 1 12-21-2003 02:16 PM
Where are my oil cooler and trans cooler located at? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-28-2002 09:40 AM
Auto-x & AT oil cooler Daios General Forum Archive 3 10-25-2000 06:15 PM
