Old 07-05-2004, 12:11 PM   #1
jacksonww1
Member#: 61624
1997 Legacy GT
Default What is that noise?
What could be rattling or ticking at the center of the motor under the intake manifold and above the oil pan? It only occurs between 1900 and 2100 rpm’s once the engine has warmed up.
Thus far I have found no leaks, no lack of power, or anything that has affected performance. The car runs perfect with the exception of this annoying and somewhat loud tick!
jacksonww1 is offline   Reply With Quote
Old 07-05-2004, 02:46 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Leaking exhaust manifold gasket maybe?
Jay
Old 07-05-2004, 03:07 PM   #3
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Timing belt tensioner
Patrick L is offline   Reply With Quote
Old 07-05-2004, 06:29 PM   #4
jacksonww1
Member#: 61624
1997 Legacy GT
Just got back from Subaru. They said the noise was inside the block. Probably the crank or a rod beariing.
Anyone know where to get a cheap bottom end or short block? In Oregon?
So far reliabilty with Subaru has been awful. I just had the top end done due to a bad head gasket at 100k. Before that, the rear bearings went, then the oil seal, then the water pump, and now the bottom goes. I never had this problem with any Honda's with over 200k on them. Just my two cents.
Thanks
Old 07-06-2004, 01:01 AM   #5
MattDell
Member#: 16803
Oh don't tell me this! I'm having a similar rattling in the same area!
MattDell is offline   Reply With Quote
Old 07-06-2004, 02:47 AM   #6
Chi_San
Member#: 53558
2002 WRX Wagon
Thanks
Sounds like a lemon to me.
Mine is doing that now. Since the engine is still under warrenty, I think I'll ask them about it. I thought mine was the exhaust heat shield? Still doing it, albiet, a lot more quietly.
Chi_San is offline   Reply With Quote
What is that noise? tirkish Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 07-08-2010 03:44 PM
What is that noise? Vicious LSD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-05-2008 07:16 PM
What is that noise?!?! awdity Off-Topic 6 09-23-2004 12:34 PM
F1 cars, what is that noise? jeffg Off-Topic 53 10-25-2003 02:23 AM
What is that noise? Chode_boy Service & Maintenance 15 09-26-2002 04:24 PM
