Old 07-05-2004, 03:08 PM   #1
zavala
Member#: 44371
Default 205? 215? 225? which has the widest tire patch for the stock rims?
since i've recently painted my stock wheels and they look really good i've decided to keep them. but, i can't decide on a tire size for some new rubbers. i've read and heard that on the stock rim putting wider tires arn't going to give you any more foot print, just sidewall buldge. i plan on going with a ?/45/16 which ever it is. thanks justin
zavala is offline   Reply With Quote
Old 07-05-2004, 03:28 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
It would help if you told us what wheel your talking about.
225s on a stock wrx rim, is too wide for the 6.5 and will probalby hinder performance.
get a 205 50 16. or 215 45 16. All depends on how off you want your speedo to be.
Jay
Old 07-05-2004, 03:29 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
225/50-16 is the best bet.
Hafta watch the load rating on that kind of thing....you may end up buying a tire that has insufficient load capability.
Old 07-05-2004, 03:34 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
225 on a stock wrx rim will cause the sidewalls to buldge, and it will affect the contact patch in my opinon.
Old 07-05-2004, 05:56 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
....well...most manufacturers list the 225/50 for a 6"-8" rim width...so....
Yeah, I'd rather see it on a 7" or even a 7.5"....but....
depends on the tire, too...some are a lot wider than others...
Old 07-05-2004, 06:05 PM   #6
zavala
Member#: 44371
they are the stock wrx rims, 16x6.5. and why a 50 series tire? wouldn't haveing a 45 make the tire spin a little faster?
Old 07-05-2004, 06:14 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
...maybe...you have to be careful that you get tires with sufficient load range...and a tire size for one manufacturer may be different for another...or even different tires.
So some research on what you are asking and you can answer your own questions...the answers are out there
Old 07-05-2004, 06:19 PM   #8
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
The lower the aspect ratio, generally the wider the rim needs to be. I was going to go with the 45 or even the 40 series but the contact patch wasn't good enough. UncleScotty pointed out the need to be carefull with the load rating and he is right, but with a little search you can find 40 and 45 series tires with the proper load range. In the end I went with P225/50R/16 in the BFG KDWS and I am very pleased, I can still turn'em over but the traction is vastly improved. Contact patch on these on stock rims is 9.50 inches.
wrx plus is offline   Reply With Quote
Old 07-05-2004, 06:55 PM   #9
zavala
Member#: 44371
well, if it helps the tire i was looking at was toyo TS1 in 225/45/16
Old 07-05-2004, 06:58 PM   #10
poison
Member#: 37678
Whoa, 9.5 in on stock rims
zavala, what car do you have?
I have a TS with stock WRX 205/55/16's. [email protected] told me that I need 205/50/16 to keep the gear ratio intended by the manufacturer. Because the 55 series is 3/4 of an in bigger in diameter than 50 series, my car is slower off the line; on the plus side the engine turns slower at any given speed.
I'll take the quickness off the line plus the shorter sidewall of the 50 series!
I'll be ordering mine soon!
Question: to keep the same size as the 205/50/16, yet get wider, would I do 225/45/16, or what?
poison is online now   Reply With Quote
Old 07-06-2004, 09:21 AM   #11
DtownIan
Member#: 31447
'82 Volvo 245
turbo/intercooled/4-spd
I had stock sized S03s on my wagon, and with a tire that sticky (as is the T1S) I didn't find contact patch to be an issue.
DtownIan is offline   Reply With Quote
What's the widest tire for my stock rims? Marillion Tire & Wheel 2 02-25-2009 11:46 AM
What's the Largest Tire to Fit a Stock Rim ?? george3 Tire & Wheel 11 03-01-2008 11:33 AM
What is the widest tire that will fit stock 07 TR Wheels RedefinedTR Tire & Wheel 11 06-30-2007 02:19 PM
widest tire size to fit stock rims. wrxracer55 Tire & Wheel 2 08-12-2003 06:50 PM
