Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 07-05-2004, 05:04 PM   #1
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Default 98 RS Fuel Rails, any plug and play injectors.
I currenty have some used injectors 400/cc, that are 'rigged' wiring wise cause the hardshell connectors dont fit on them.
I would like to eventually put something in that fits properly.
I was looking at a picture of the 04 usdm sti injectors and they look similiar...but im probalby wrong.
what are you running that fits. Or that you have made fit.
Jay
Old 07-05-2004, 06:20 PM   #2
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
the 04 usdm sti injectors will not fit.
NeaD is offline   Reply With Quote
Old 07-05-2004, 07:50 PM   #3
Unsung Boxer
Member#: 37196
(wasnt i the one who told you that? I told you I heard they dont fit, so I hope your not giving him info based on me)
Why put in different injectors just because you dont like the wiring. How about you just do a nice job w/ the wiring. Get yourself some nice butt connectors and some heat shrink tubing. (make sure you are careful using the heat gun around the fuel)
-Jake
Unsung Boxer is offline   Reply With Quote
Old 07-05-2004, 08:16 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
They are wired nice right now, Rallispec pulled the terminals out of the hardshell connectors, heatshrinked each terminal and just plugged them in idividuatlly. Im still worried about corrosion though.
I dont like the fact that I dont know what type of injectors I have or their origin.
Jay
Old 07-05-2004, 08:21 PM   #5
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
McDade - the old school WRX STi injectors from a V4 or V5 will fit. They're 440cc IIRC yellow top. Also the SR20DET stock injectors will fit (370cc though; will require terminal mods though).
GTBGUY is offline   Reply With Quote
Old 07-05-2004, 08:39 PM   #6
Unsung Boxer
Member#: 37196
you dont like the idea? Ok, basically ur gonna pay a bunch of money for a plastic plug. If its such a big deal, wire the other injectors into the factory plug for the 400 injectors, yeesh
ur money, waste it however u want
-Jake
Old 07-05-2004, 08:41 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
GTBGUY thanks for the info!
Jake, yup thats me LOL, I cant wire the aftermarket injectors into the factory plug...thats the problem
Jay
Old 07-05-2004, 08:43 PM   #8
Unsung Boxer
Member#: 37196
arent they 400's out of another vehicle? what im saying is get the harness plug that is meant for your 400's, and wire that in.
Sorry, i wanst clear
-Jake
Old 07-05-2004, 08:45 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
-Jake
Yea thats the problem, I have no idea what kind of car they are out of. I dont think the previous owner knows either. I would do that if I could.
GTBGUY do you happen to know if the fuel pressure regulator from a v4/5 STi is bolt in on the 98 RS Rail as well?
Jay
Old 07-06-2004, 12:20 AM   #10
GTBGUY
Member#: 2003
'99 BGP Legacy GT
McDade - you shouldn't need to run the V4/V5 regulator etc... however I'm going to have to dig them out of the spare parts bin to do a comparison. The injectors dropped right into the Phase 1 DOHC fuel rails on the EJ25.
Old 07-06-2004, 05:37 PM   #11
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
Here is a question I was thinking about...how hard would it be to convert the 98 rails to a custom top feed rail???
Andursun0013 is offline   Reply With Quote
Old 07-06-2004, 06:52 PM   #12
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
GTBGUY, I asked about the regulator becaues I dont think the RS regulator is keeping up with the supra pump and injectors I have now.
Jay
Old 07-07-2004, 01:31 AM   #13
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Andursun0013 - it's a real PITA Fortunately with the old school Phase 1 side feed, it's been noted that it's less likely to be lean in a cyl. The config is the same as the STi config.
McDade - You may want to forgo the stock regulator or even try an external one. I'll check to see if there's any P/N's on the STi regulator I have... if it's the same you know it's no good to swap that into the rails
Old 07-07-2004, 05:49 PM   #14
Andursun0013
Member#: 11616
1998 2.35RS-T
not what i was hoping to hear...guess i'll have to start checking out nismo injectors
Kyle
Old 07-07-2004, 05:57 PM   #15
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
I was looking at the vortech, but I dont think it will help on decel...Decel is when I have my problem with flooding
Jay
Old 07-08-2004, 12:08 AM   #16
GTBGUY
Member#: 2003
'99 BGP Legacy GT
McDade - Did you upgrade your fuel return lines yet? You may want to move to a -6AN size to aleviate that.
Agency side feed fuel rails and stock pressure regulator, true Plug and play Red_Wrx SCIC Private Classifieds 3 01-21-2011 01:02 PM
T1 RaceDevelopment Top Feed Fuel Rail Conversion Kit and ID2000 Injectors Junior2JZ Vendor Reviews 6 09-22-2010 01:17 PM
Are the PE injectors direct plug and play? gtasti Newbies & FAQs 8 06-20-2008 03:26 PM
EJ20G Injector Upgrade, STi 550's with RS fuel rails. 150.00 Shipped! snowman4us 1993 - 2001 Impreza Specific Parts 5 11-30-2007 12:15 AM
Injectors that will fit 2000 RS fuel rails Trizzle Normally Aspirated with bolt-on Forced Induction Powertrain 3 08-06-2003 02:26 PM
