Old 07-05-2004, 08:07 PM   #1
eightballrj
Member#: 18520
2005 L GT Limited
Default A sway bar is a sway bar is a sway bar??
I am about to be in the market for a sway bar set or just a rear sway. I just bought the cheapy whiteline rear endlinks so thats already done. I just wanted to know if the sways were all pretty much the same. Thanks. Also, help me out... My setup is right now RA-C struts and springs, steering bushings, nice tires, subframe locks, and rear diff Xmember bushings. What would you say will be the most beneficial?? My next mod will either be the sway or sways or front and rear STB's. Do you think I ought to get the front and rear sways or just the rear(autocross and performance daily driver)?
Thanks again,
Richard
eightballrj is offline   Reply With Quote
Old 07-05-2004, 09:51 PM   #2
TGITI
Member#: 63365
02' WRX Sedan
COBB Stage 1
Having both front and rear sway bars will balance out the car nicely, but I think your really only need the rear for more oversteer. I would go with the matching Whiteline bar--excellent products.
TGITI is offline   Reply With Quote
Old 07-05-2004, 10:33 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I'd get the swaybars and urethane mount bushings F/R...and if you must have a STB...just get the rear one...the Whiteline adjustable one, 'cuz you can crank it tight
Old 07-05-2004, 10:53 PM   #4
eightballrj
Member#: 18520
2005 L GT Limited
So, Whiteline front and rear sways with the mounts and then later maybe the rear STB? Sounds like a plan to me. Now I have to figure out my money situation , haha.
Thanks,
Richard
Old 07-05-2004, 11:10 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
Thanks,
Richard
Do the '04 WRX rear mounts...~$30 shipped from subaruparts.com....I'll see if I can round up the P/N's for ya
...and the bars will come with bushings...no front mounts needed
ok...P/N's for rear '04 WRX swaybar mounts...
1 20540FE200 Brkt Stabilizer Rh
1 20540FE210 Brkt Stabilizer Lh
2 20466FE000 Clamp Stabilizer Bsh
Old 07-05-2004, 11:17 PM   #6
eightballrj
Member#: 18520
2005 L GT Limited
Hey Unc,
Pardon my ignorance but what is the difference in the mounts that makes them worth buying? Thanks for the P/N's if you can find um or thanks for looking if you can't. Well, nevermind then, haha. Thanks for finding them . So, would you say that I am on the right track suspension wise?? I am just now learning more about our suspensions.
Richard
Old 07-06-2004, 12:35 AM   #7
punkrocksailor
Member#: 43376
Buy a Perrin bar, it comes with better mounts than any I've seen.
Cheers,
Joel
punkrocksailor is offline   Reply With Quote
Old 07-06-2004, 07:58 AM   #8
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Here's a nice writeup with pics
http://www.clubwrx.net/forums/showth...&postid=460165
You will need the new style rear bushings, too (or if you do this, make sure you ask for 2004+ bushings, as they are a little different (some people have made them work, but since you are getting new ones anyway, you might as well do the job right!))
On the install page, a number of people make it sound very difficult - it's actually a very, very easy job if you have the right tools - those being a ratcheting 12mm wrench and a 12mm swivel socket with a decent length extension bar - it's literally a 15-20 min job.
will 04 sti sway bars fit 04 wrx and is it considered an "upgrade" MAtwal Transmission (AT/MT) & Driveline 1 01-22-2010 12:06 AM
Is an 04 USDM STI front sway bar identical to an 04 WRX sedan front sway bar? legacy2003 Brakes, Steering & Suspension 1 10-01-2009 05:25 PM
Is there a best brand for sway bars and end links? jcbluescooby Brakes, Steering & Suspension 9 07-21-2009 11:44 PM
is a clunking sound normal after sway bar install? truenosan Vancouver Impreza Club Forum -- VIC 16 10-22-2008 08:52 AM
What is the org. size of rear sway bar? AC Legacy Forum 5 03-29-2001 10:40 PM
