Old 04-26-2004, 12:28 AM   #1
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
Default 2004 Wagon Springs - Real Options
After much searching and reading, I thought it best to start a sort of consolidated thread.
As of right now, there seems to be very little solid information on springs for 2004 wagons.
Correct me if I am wrong:
-Prodrive never makes wagons specific springs.
-Eibach makes wagons specific springs, but not yet for 2004. And know one knows if they ever will.
-Whiteline suposedly makes 2004 springs, but the PDM website has a "NA" for the rear springs.
-Tein is not making a wagon specific spring for 2004.
Am I missing anything?
Basically, as far as I can tell, no manufacturer specifically recommends springs for the 2004 WRX wagon. In about three weeks I will have had my car for a year. Frustrating. I realize that people get good results using non-wagon specific springs, but it bothers me that the manufacturers are not specifically recommending them.
brizey is offline   Reply With Quote
Old 04-26-2004, 02:24 AM   #2
Mark Avery
Member#: 10313
2002 WRX wagon
>2004 WRX wagon
Not true, they don't make wagon specific springs, but they say sedan springs will work fine on a wagon, and they're right.
The wagon is slightly heavier in the rear than a sedan, and it's stock springs are slightly stiffer in the rear to compensate. In the world of even stiffer, lower springs, the front to rear stiffness ratios aftermarket companies are engineering into their product work fine with a wagon. Putting sedan springs on a wagon might result in a slightly different balance, but it's not a "problem."
Also Whiteline's website gives rear part numbers for 04 specific Control and Flatout springs - sedan, not wagon. (Actually the rear suspension design change came in 03 for Japan and Australia.)
You can find a lot about spring rates here: http://www.northursalia.com/t...ng/spring.html
Mark Avery is offline   Reply With Quote
Old 04-26-2004, 05:13 AM   #3
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
TEIN has them man...
From Z-1's site:
For 2004 WRX sedan, wagon, and STi model:
H-Tech: lowers your 2004 sedan -1.8 inches front, and -.7 inches in the rear, and features spring rates of 229 lbs front, 196 lbs rear. For the 2--4 STi, they lower the car -1 inch up front, -.4 in the rear, and feature spring rates of 229 lbs front, 196 lbs rear. For 2004 wagons, lowers the car -1.5 inches up front, -.4 inches in the rear, and has spring rates of 229 lbs up front, 196 lbs rear.
S-Tech: lowers your 2004 sedan or wagon -2.4 inches front, -1.3 inches rear. Lowers the STi -1.6 inches front, -.9 inches rear. For 2004 WRX sedan and STi sedan, features spring rates of 240 lbs front, 207 lbs rear. 2004 wagons have spring rates of 218 lbs front, and 157 lbs rear.
MK19_ is offline   Reply With Quote
Old 04-26-2004, 07:08 AM   #4
brizey
Member#: 36505
Thanks for the late night replies.
Hopefully this thread will pop up in searches. I did something like 15 searches last night.
Old 04-26-2004, 07:01 PM   #5
Mark Avery
Member#: 10313
2002 WRX wagon
Tein markets the same spring for WRX sedan, wagon, AND the STi - check the part numbers. The drop is slightly different on each because, well, it's a different chassis. Those spring rates are for the STi. I wouldn't use them with stock WRX struts.
The info on Tein's website is a bit suspect. For the 04 wagon it lists the same part number as WRX sedan and STi, but it lists a different spring rate. It is, however, the same spring rate as the 02-03 springs. Huh?
Old 04-26-2004, 10:35 PM   #6
brizey
Member#: 36505
Hmmm. I really wish a major parts maker liker Eibach or Prodrive would come out with a spring set and said "This is the one for a 2004 WRX wagon with stock struts." I may just go with the Eibachs's for '04.
(Edit, subbed Eibach's for Tein's).
Old 04-27-2004, 01:10 AM   #7
Mark Avery
Member#: 10313
2002 WRX wagon
Eibach made a wagon spring for 02-03, but apparently it wasn't a big seller - no rush on an 04 version. I've heard of plenty of wagon folks happy with the Prodrives. They work fine on a wagon.
Old 04-27-2004, 08:44 AM   #8
occytron wrc
Member#: 28788
01 boring sedan
w/roof dent!
The prodrive 04 springs are supposed to be for both sedan and wagon from what I have read. They were supposed to have come out awhile ago, but apparently they are "on the boat". Myles at RaceCompEngineering told me that they are supposed to be hear by May 15th. I am looking forward to hopefully trying them. I am in the same boat as you in having trouble finding a spring for an 04 wagon. I am not sure about the Tein's. I read a lot of posts from people saying that they would never put them because the drops are too much.
Now the waiting begins.
occytron wrc is offline   Reply With Quote
Old 04-27-2004, 11:24 PM   #9
brizey
Member#: 36505
Occy:
Please PM me or post a review in this thread when (if?) you get the Prodrives.
Thanks,
Brian
Old 04-28-2004, 10:32 AM   #10
jawbrkr
Member#: 37822
2004 Uber Stock WRX
I did some research, and I'm running sedan tein s tech with kyb agx's.. The only reason I went with the tein s tech
a. we have limited options
b. the springrate difference was so minor, (10 ft/lbs) it wouldn't really matter
c. the wagon is only 80 lbs heavier, so its like driving around with two spare tires in your trunk. Which on the flip side can be good because you have more weight pushing down on the tires.
jawbrkr is offline   Reply With Quote
Old 04-28-2004, 04:00 PM   #11
C2H5OH
Member#: 39924
2003 WRX
Cant you just switch to 02/03 rear strut tops? That would open some options...
C2H5OH is offline   Reply With Quote
Old 04-28-2004, 10:29 PM   #12
brizey
Member#: 36505
I guess I am just getting overwrought. I was under the impression that the struts were different beyond the tops. But the reality is that changing the unsprung weight with new wheels and tires kind of throws the whole "designed to work with the stock suspension" out the window anyway, and I plan to get 17" wheels when the stock tires wear out.
Heck, springs are not that great of a performance mod anyway.
Old 04-28-2004, 11:24 PM   #13
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
A few board members have heaped praise on the '04 suspension. I'm kind of on the fence as to whether springs are really worth it for my '04 wagon. I don't know if there is enough of a performance increase, and I don't want to lose ground clearance just for looks. I would definitely consider '02/'03 strut tops and a set of Prodrive springs if I was going to do it.
<--------------- Confused
Jard is offline   Reply With Quote
Old 04-28-2004, 11:53 PM   #14
Mark Avery
Member#: 10313
2002 WRX wagon
The 04s have a revised rear spring/strut top design, and the struts have different multi-phase valving. A stock 04 is supposed to be a better ride than a stock 02-03. But, it's still a fairly soft setup.
Add 02-03 rear strut tops and you can use the old design springs no problem, and the new struts will still work fine with Prodrive springs.
Old 04-30-2004, 10:50 PM   #15
brizey
Member#: 36505
Mark:
Thanks for spending so many keystrokes on an old noob.
Brian
Old 05-01-2004, 01:14 AM   #16
tucker63
Member#: 41326
2005 M3 smg, 06 LGT
I just installed 04 pinks with Koni's on my 04 wagon and I am pleased. The ride is a little bouncy at high speed but I am still working on dialing in the struts. I have a novice autox school this weekend so I will find out more on Sunday. Tucker
tucker63 is offline   Reply With Quote
Old 05-01-2004, 10:22 AM   #17
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Mark Avery is spot on about the suspension revisions on the '04 WRXes. But the '04 WRX wagon is, to this butt, significantly firmer than an '02-'03 WRX wagon. I test-flogged one, and that car is a sedan swaybar and rear STi pink links package away from being a superlative handler.
Springs are always a compromise, because a) they will, however incrementally, shorten the life of the stock struts and b) they take the stock struts out of the preferred range of travel, which explains why ride quality often deteriorates when springs are added to a car.
I have the SPT wagon suspension kit on my '02 wagon, and after driving the '04, then getting back into my car, my car wasn't a whole lot firmer. Were it my '04 wagon, IMHO, instead of looking at springs, I would:
1. get a sedan swaybar
2. get some of the pink STi lateral/trailing links at the rear
3. go for that 17" package, if you still think you need it after feeling how well the car works with the above two.
4. drive happy
Kevin
gtguy is offline   Reply With Quote
Old 05-18-2004, 03:13 AM   #18
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
I wonder whether there will be a SPT wagon kit for MY04, like the ones for MY02-03. Anyone knows?
Gunner is offline   Reply With Quote
Old 07-02-2004, 04:53 PM   #19
BIGSKYWRX
Member#: 7958
09 GH B+
Not likely- sadly FHI isn't making the GGB anymore. That is what the SPT it was based on- just oem STI wagon bits. No more STi wagon, not likely a SPT 04 wagon specific kit.
I just swapped from the sedan to the wagon and ran the STi RA setup on my sedan- I loved it. I'm going w/ the 02/03 STi wagon springs/struts, combined w/ the Grp N tops (02/03 rears). If the "normal" STi spring rates aren't quite what I'm looking for, I'll pickup a set of RA springs. Sedan springs will work fine w/ the wagon- even STi's aftermarket "pinks" list one part # for both wagon/sedan. The spring rates oem are the same in the front w/ a very slight increase in the rear for the wagon (very slight).
Big Sky
BIGSKYWRX is offline   Reply With Quote
Old 07-03-2004, 10:44 AM   #20
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
i have H-techs on stock struts and a 20mm RSB on my wagon and love it.
Quack is offline   Reply With Quote
Old 07-03-2004, 05:22 PM   #21
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
As mentioned in another thread, I'm going w/ takeoff 04 USDM STi springs/struts and mounts on my 02 WRX wagon. I'll be adding camber bolts in the rear and group-N topmounts in the front. I have been forewarned that I may not get adequate camber in the front--in which case I will swap in camber plates.
Subahaulic is offline   Reply With Quote
Old 07-04-2004, 04:39 PM   #22
Integra96
Member#: 64196
2010 Family Sedan
Let's all camp out in front of H&R or Prodrive headquarters and demand them to release '04 springs (angry village mob style).
Integra96 is offline   Reply With Quote
Old 07-05-2004, 02:01 PM   #23
jmnjn1
Member#: 48736
2004 Wrx Wagon
WR Blue
2004 WRX Wagon with Eibach ProKit installed and loving every minute of it...
(Heard Eibach makes Prodrive's springs. So in a sense you are getting Eibach's when you buy Prodrive.. )
jmnjn1 is offline   Reply With Quote
Old 07-05-2004, 02:13 PM   #24
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
...yeah...but they are different rates/lengths
Old 07-05-2004, 03:09 PM   #25
BIGSKYWRX
Member#: 7958
09 GH B+
I'm going to take back my comments on sedan springs working fine- they may and they may not.
v7 STi pinks- not wagon or sedan specific. Advertised drop 20mm f/r, w/ sedans this is prety close to what they get. What I'm finding out is that w/ the wagon (and these are wagon specific ST struts mind you) they're seeing a 20mm drop front, but in the neighborhood of 48mm drop in the rear!
My guess is there is a significant differnce in free length between the sedan and wagon rear springs- this is supported by GGB and GDB using different springs (but the same rates).
I'd like to hear from folks trying different non wagon specific springs w/ ride heights front/rear (measurements should be taken from center of wheel -straight up to the wheel arch).
Not good news when I found this out about the v7 pinks
Big Sky
2004 sti blown struts... options while keeping OEM springs? InfamousDX Brakes, Steering & Suspension 1 10-19-2009 04:49 PM
light bar options for a 2004 wagon? flyingmachine Interior & Exterior Modification 2 08-01-2005 03:34 AM
OEM 2004 STi springs on a 2004 wagon Unabomber Brakes, Steering & Suspension 27 07-27-2004 08:10 AM
A real option for 2004 WRX wagons? Integra96 Brakes, Steering & Suspension 4 07-07-2004 06:58 PM
91 legacy wagon spring options? 206legacy Brakes, Steering & Suspension 3 06-25-2003 11:53 AM
