Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 10-30-2000, 08:22 AM   #1
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post MY00 AFC tuning notes
Finally had a chance to wind out the RS at high rpms in 4th on a long drive yesterday, & here's what I noticed:
EGT's are around 1250 at WOT from around 1500-3500 rpm --> running rich... corrected by about -4%.
From 3500-redline, the EGTs move up to 1500 --> running lean... corrected by about +4% for now, haven't had a chance to fine tune that value yet, but I know it runs lean, especially since my Autometer EGT probe is kinda slow.
MY00 RS, intake, 2.25" catback, pulley
I'm also running a +4% at low throttle at 1500 rpm to get rid of the pinging. For some reason, b/t 3500-4000 rpm, the car pings at about 15% throttle (& the EGT's start to rise if held there), but not with more or less throttle. *shrug*
RidinLow is offline   Reply With Quote
Old 10-30-2000, 05:04 PM   #2
nizz
Member#: 188
2004 Forester XT
24k gold on white
Question
Garrick,
This is with what octane gasoline?
nizz
nizz is offline   Reply With Quote
Old 10-30-2000, 05:50 PM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
93
Old 10-30-2000, 08:41 PM   #4
IMPBOY
Member#: 65
Post
This proves that I wasn't crazy when I said my 00 runs lean.
IMPBOY is offline   Reply With Quote
Old 10-30-2000, 09:31 PM   #5
Hashiriya
Member#: 2798
2002 GDA
Midnight Black Pearl
Question
Sorry to butt in but I just got a AFC for my MY00 and got it wired in. But when I started to work on it I could figure out all the info about my car. Can you tell me what kind of sensor the MY00 has and all the other things the AFC asks for.
Hashiriya is offline   Reply With Quote
Old 10-31-2000, 10:21 AM   #6
the spacecowboy
Member#: 765
Post
yes....please post as much as possible.....
im getting a afc and i would like to know as much as i can before i start messing with it...
also where can i get a wiring diagram
thanks,
space
the spacecowboy is offline   Reply With Quote
Old 10-31-2000, 11:40 AM   #7
Hashiriya
Member#: 2798
2002 GDA
Lightbulb
I got my diagram at geocities and searched for "Impreza super AFC" I cant remember details but someone had a nice diagram.
Old 10-31-2000, 02:08 PM   #8
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Post
the MY00 has a pressure sensor. MY98-99 has a MAF sensor.
Eric
Eric SS is offline   Reply With Quote
Old 10-31-2000, 04:45 PM   #9
Hashiriya
Member#: 2798
2002 GDA
Question
So what do I put for the part after the no. of cylinders with the arrows?
Old 10-31-2000, 05:25 PM   #10
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
no. of cylinders = 4
ImprezaRS dot com is offline   Reply With Quote
Old 10-31-2000, 05:27 PM   #11
Hashiriya
Member#: 2798
2002 GDA
Question
duh , what's the arrow marks and the ** for?
Old 10-31-2000, 05:47 PM   #12
Keirik
Member#: 507
2005 Saab 9-2x Aero
black
Post
hey ridinlow,
So what value are you shooting for here with the o2 sensor .87? I still never got my AFC tuned................by the way, if I use 89 octane, should this change anything? My car runs better under 89 than 93.
Keirik is offline   Reply With Quote
Old 10-31-2000, 05:55 PM   #13
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
I dunno, I've never looked at the O2 sensor voltages since they're not gonna be anywhere as accurate as my EGT gauge.
Old 11-01-2000, 07:14 AM   #14
Hashiriya
Member#: 2798
2002 GDA
Question
Someone help me out here, what's the sensor no. for the MY00? I know it's a pressure sensor but what do I input for the in/out no. on the AFC?
Old 11-01-2000, 02:18 PM   #15
bluesaint
Member#: 876
Post
the EGT autometer i would believe to be just as accurate as looking @ ur AFC since both are getting the information from the same place. On my MY00 with pulley,intake,exhaust I run RICH starting @ 3000rpm
bluesaint is offline   Reply With Quote
Old 11-01-2000, 02:25 PM   #16
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Hashiriya, sorry if I keep ignoring you, but I don't remember what car settings I have in my AFC, but I'll check the next time I go out.
Bluesaint, the EGT probe and the O2 sensor are not getting their data from the same place. The EGT probe is reading exhaust gas temperatures right after the exhaust valves. The O2 sensor is detecting the amount of O2 in the combusted mixture. In a MY00, the AFC can only monitor the rear O2 sensor. This results in a lean reading because the cat has cleaned things up a bit. The front O2 sensor can't be read because it's wideband.
So unless somebody comes up with a way to read the front O2 sensor, EGT's are the only reliable way to tune the MY00, IMO.
Old 11-01-2000, 02:50 PM   #17
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Post
You know, there's always a way to convert a "wideband" signal to a "narrowband" signal (from an RF point of view, those terms are sadly misused). Just rig up a simple inline op-amp circuit that scales down the input voltage. Then you can feed it to the second S-AFC input.
Even if the scaling isn't exactly linear, you can always calibrate the stoichiometric points to match. Then you can mentally correct for the rich and lean amounts as necessary. In fact, it wouldn't be much more of a stretch to create a display like the A/F bargraph on the J&S Dual Monitor.
-WaC
Wayne
97 OBS
wac is offline   Reply With Quote
Old 11-01-2000, 07:37 PM   #18
ImprezaRS dot com
over boosted again
Member#: 1458
Post
The Blitz FATT turbo timer (Fully Auto Turbo Timer) has a neat accessory you can buy for it, the A/F analyzer, and it comes with it's own O2 sensor! This displays on the turbo timer's digital display.
This is next in line to buy, along with fuel pressure gauge and Brake rotor/pad combo...
Larry www.ImprezaRS.com
Old 11-01-2000, 07:45 PM   #19
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
But having 3 O2 sensors in the system just seems ridiculous, IMO...
Element Gt52 tuning notes - great unit Dyno Flash Proven Power Bragging 97 06-07-2007 06:03 PM
Some tuning notes (from PPB) PDXTuning Engine Management & Tuning 18 04-20-2005 02:48 PM
anyone with MY00 and AFC tuned? Keirik Normally Aspirated Powertrain 4 10-23-2000 09:01 AM
