Old 08-22-2004, 11:40 AM   #26
mowgli
Member#: 57435
Default Lost .5 in 1/8th with typhoon
I installed a typhoon with a stock Sti and lost 5 tenths in 1/8 mile. Thought it need to relearn drove for a week went back and same result. Switched back to stock at track and next run went back to my average times
mowgli is offline   Reply With Quote
Old 08-22-2004, 12:30 PM   #27
mnavarro
Member#: 51537
2004 WRB WRX STI
62 Corvette/11 Cherokee L
mowgli, is this the sti specifc baffled short ram, short ram, or cold air intake. It seems there are a few different styles. Thanks.
mnavarro is offline   Reply With Quote
Old 08-22-2004, 04:11 PM   #28
mowgli
Member#: 57435
Default Sti specific
I would not believe it if I didn't test it. My car runs 8.6 all day long stock in 1/8, with k&n the best it would do 9.2/9.1. I guess the computer sees too much air and backs it off. Also I remove the stock air filter and it slowed it down also. I guess with engine mangement it may add performance. I am installing a downpipe and mid pipe and see what happens.
Old 08-22-2004, 04:43 PM   #29
mnavarro
Member#: 51537
2004 WRB WRX STI
Well I've got engine management so I'm not too worried, but I guess it's proof that the dyno and the realworld often are not aligned. I think that the truth is you won't see any real performance gains with intakes on the STI without engine management period.
Old 08-22-2004, 05:28 PM   #30
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
How exactly did you determine that it was the result of the intake? No det? Fuel? Weather? Etc...
-st
singletrack is offline   Reply With Quote
Old 08-22-2004, 08:53 PM   #31
mnavarro
Member#: 51537
2004 WRB WRX STI
Well, one thing for sure is that the loading of a 1/8 mile run is lot different than a 3rd gear pull on a dyno, so the results are not surprising even if all things are equal. If ANYTHING is different and the engine is highly loaded the ecu may react by pulling timing. It is known that the STI can knock stock without additional mods. So, more than likely an intake without engine management is a waste of money.
mowgli, it would be cool if you boosted the octane of your gast to see if that would help any.
Old 08-22-2004, 09:16 PM   #32
mowgli
Member#: 57435
I'm not giving up on the typhoon. I determined that it was the intake because I switched at the track. Did back to back runs. I'm all for dyno's for tuning but in the real world its all about getting down the track
Old 08-26-2004, 05:06 PM   #33
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Good info.
~v6
V6TurboTA is offline   Reply With Quote
Old 09-09-2004, 06:14 PM   #34
STiGMA
Member#: 68054
2004 WRX STi
Java Black Pearl / Gold
Mowgli-
Stupid question, but when you installed the intake you did disconnect the battery and and grounded the positive cable (disconnected from battery of course) to clear computer memory so that it could relearn?
STiGMA is offline   Reply With Quote
Old 09-09-2004, 07:36 PM   #35
RChampion
Member#: 21481
99 2.5RS
14 Impreza STI
Never hurts when you change something about your car. Not always necessary.
RChampion is offline   Reply With Quote
Old 09-09-2004, 09:35 PM   #36
SINthetic
Member#: 53775
03 WRX
This system does look nice.
SINthetic is offline   Reply With Quote
Old 09-09-2004, 11:45 PM   #37
mowgli
Member#: 57435
Yes I reset the computer no difference
Old 09-10-2004, 04:37 PM   #38
ninjaboy76
Member#: 33456
2015 WRX
WRBP
Anybody here have a Typhoon with the heat shielding they want to sell??
ninjaboy76 is offline   Reply With Quote
why tacomas no depreciate, why not friedbbq Off-Topic 25 09-03-2005 01:08 PM
Why are no-no parts naughty? wyn525i Off-Topic 30 12-01-2004 11:52 AM
Why Subaru no black STi?? norseone STi Forum Archive 19 05-22-2003 11:09 AM
TC mods....why has no one used Precision Industries? Hit Man X Transmission (AT/MT) & Driveline 9 02-22-2003 01:18 AM
Why is No spoiler better? el~sharko Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-09-2002 08:06 PM
