Old 07-06-2004, 03:57 AM   #1
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
Default what Gasket Thickness did you use in your turbo RS?
i would like to know:
1. what head Gasket Thickness did you use in your turbo RS?
2. what piston do you have?
3. how much boost are you runing?
4. do you have any problem?
because i was useing 0.58mm head gasket and i blow it after 1200 miles right after I start to run 1.3bar boost.
ChAi is offline   Reply With Quote
Old 07-06-2004, 05:11 AM   #2
kaos200
Member#: 2692
stock STi gasket.
stock pistons (as of this moment)
1bar on pump (91)
not yet. (knocks on wood)
kaos200 is offline   Reply With Quote
Old 07-06-2004, 05:11 AM   #3
kaos200
Member#: 2692
ps, dont use the crappy stock RS gaskets. Get the 257 ones
Old 07-06-2004, 05:23 AM   #4
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
1. 2000 2.2 Impreza L head gaskets
2. ej22T block with SOHC 99 heads
3. Had it up as high as 30psi- typically run around 22
4. Not yet
Drac9 is offline   Reply With Quote
Old 07-06-2004, 11:23 AM   #5
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Cometic .043"
Ross Racing Forged
18psi
No problems so far except for the 13/14MPG.
Wedge is offline   Reply With Quote
Old 07-06-2004, 02:08 PM   #6
omarudy
Member#: 23738
Default gasket
i use the cometic head .043gasket (2004sti) on my hybrid 2000 rs heads with 2004 sti shortblock
omarudy is offline   Reply With Quote
Old 07-06-2004, 10:00 PM   #7
inpreza kid
Member#: 3334
the cometic HP version (0.043") headgasket is pretty good. has a fire ring around the center bore. very nice quality. i've heard of local guys boosting 20psi with the phase2 0.058cm stock headgasket long term without problems on a ej22t/sohc hybrid.
inpreza kid is offline   Reply With Quote
What 12V source did you use for your WI kit? efmd3 Water/Methanol Injection, Nitrous & Intercooler Cooling 12 06-25-2008 03:35 PM
what head gasket did you use on your EJ22t hybrid? 2.5rsDOHC Built Motor Discussion 18 09-13-2007 10:16 AM
What engine oil do you use in your subies Sacramento? MAJRMSA Bay Area Impreza Club Forum -- BAIC 1 12-03-2005 07:01 PM
What Tire Pressure Are You Using In Your Snows? slowme Brakes, Steering & Suspension 1 11-01-2002 08:42 AM
('93-'01) What kinda wax do you use on your Blue ridge pearl RS 2.5rsMI Impreza Forum 6 07-17-2001 08:27 PM
