Old 07-06-2004, 09:04 AM   #1
Mr_Blastman
Member#: 58075
2004 WRX Wagon
Default So I got my new BBS wheels on
Well, yesterday I got my new STi BBS Gold wheels on my 04 WRX Wagon. I am so amazed how much better the car handles from the stock wheels/tires.
So far, I am not noticing any rubbing. Is there a distinct noise I should be on the lookout for to know that some rubbing may be taking place? I'm going to listen to them carefully for the next few days to make sure everything is ok.
One other point to mention is all wheels are the same circumference except for one in the right front - it is about .375 an inch larger (this is the tire tread) than the others. Should this make a difference or should it wear down into line with the other tires? We put it on the front since there is no LSD up front to worry about. I got the tires for free so I figured I'd use them for a bit til I can afford some RE 950's for the wheels. I took some pictures yesterday, but haven't uploaded them yet to the web
Mr_Blastman is offline   Reply With Quote
Old 07-07-2004, 07:36 AM   #2
Mr_Blastman
Member#: 58075
2004 WRX Wagon
bump for some sort of response:
Still wondering about how to check for rubbing and tire circumference. There's a lot of ppl out here in tire and wheel, someone has to have something to say
Old 07-07-2004, 07:40 AM   #3
thrdeye
Member#: 24569
2011 Impreza WRX
.375, I think, will not matter.
As far as rubbing goes, you'll know it when you hear it, but rubbing may not even occurr if you aren't driving hard and pitching the car heavily.....like autocross.
thrdeye is offline   Reply With Quote
Old 07-07-2004, 01:13 PM   #4
yakker
Member#: 1330
Don't sweat the rubbing issue. If you're at stock height that is. The wagons fit 225s fine at stock height. Heck, mine don't rub even when the car is loaded down with a bunch of people and gear.
If you hear rubbing from the rear, just pull off the rubber trim piece along the top of the wheel well. You should do this anyway if you live in a salt belt like the northeast. That rubber strip will only promote rust in the rear quater panel.
yakker is offline   Reply With Quote
Old 07-07-2004, 02:35 PM   #5
Mr_Blastman
Member#: 58075
2004 WRX Wagon
I've taken some pretty hard turns already - there's this one I take into the office and on the RE92's it'd drift all the way through it and howl like mad. With my new wheels I don't really hear anything except maybe a low pitched squeal on occasion - they handle sooooo much better than the stock wheels/tires. I'm running the Bridgestone 070's on the car now. Much grippier but man are they noisy.
Old 07-07-2004, 03:35 PM   #6
KenM
Member#: 353
2014 Forester XT
Satin White
You'll also know your rubbing if you can smell burnt rubber.
KenM is offline   Reply With Quote
Old 07-07-2004, 03:42 PM   #7
Rally1
Member#: 20633
Default Re: So I got my new BBS wheels on
http://forums.nasioc.com/forums/sear...by=&sortorder=
Let's see the pics!
Rally1 is offline   Reply With Quote
Old 07-07-2004, 04:32 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Just a thought.... You can always use masking tape in the areas you think may be rubbing. Load up the car, take it for a drive and then check the tape. It should be pretty evident at that point if there was any contact.
Kean is offline   Reply With Quote
so i got my new Fish tank 125gal Wookie768 New England Impreza Club Forum -- NESIC 17 08-20-2007 08:39 AM
Got my new ERZ catback on my 92X.... Craigs92X Member's Car Gallery 14 05-18-2007 02:58 AM
So i got my new digital camcorder [27] Texas Impreza Club Forum -- TXIC 5 01-08-2003 08:50 AM
so i got my new straight pipe put on p7r4e7y Texas Impreza Club Forum -- TXIC 6 12-27-2001 03:06 PM
So I got my new car.AutoX fans help me out. socal2.2 Motorsports 2 03-10-2001 11:33 AM
