Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 04-30-2001, 10:06 AM   #1
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Post Anyone need parts from a 1990 Integra?
I've about scavenged my Integra for useful items that I need. It still has a bunch of stuff left for anyone who needs any Integra parts (a longshot on an Impreza board, I know) but before I donate it, I figure I'd give anyone a chance to pick up parts they might need. I don't plan on charging for any reasonable needs.
Pretty much all of the interior is left, it's a medium blue interior, faded, but in okay shape. Mostly all I've taken is the jack,and would like to keep the rims/tires. The engine severely overheated, so much of that is gone, but there are salvagable parts from it. I also have the stock stereo (AM/FM/cassette...yay!). Doors were recently repainted the factory medium/dark blue metallic due to a break in attempt, partial front fender painting also, for blending the color of old and new paint.
Just wanted to see if anyone needed anything before it went off to 'car heaven'.
Concillian is offline   Reply With Quote
Old 04-30-2001, 10:23 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Post
Try posting it here. You should be able to sell some of that stuff. OR if you really want to give it away, make a "free stuff in the Bay Area" post. If you are not registered and have trouble, send me a pm and I'll let you use my userID
http://hybrid.honda-perf.org/alley/index.shtml
Matt
Old 04-30-2001, 10:55 AM   #3
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Post
Does the Integra use the same kind of door speaker mount as the old Impreza? It's a plastic adaptor ring that has four screws on one side (for the speaker) and three on the other (for the door). I need a pair of those if you happen to have em, because the WRX doesn't come with the adaptor unless you get the premium sound system.
Necromancer is offline   Reply With Quote
Old 04-30-2001, 11:44 AM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Post
Hmm, I didn't think to check when I had the door panels off yesterday. I pulled my 6.5"s out of the Integra and checked to see if they'd fit anywhere in the WRX, but as you know, it's a no-go.
That would be a nice bonus if the adapters were the same. I don't know if I'll have time to check tonight, I'll check tomorrow.
Old 04-30-2001, 01:52 PM   #5
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Post
Joe, I didn't try the adapter, I was just trying to fit the speaker directly into the door. In fact, I left the adapters on the Integra. The 6.5's look as if they'll physically fit, if they have the right flange adapter for the screw holes.
Sin4lly: Left front headlamp, okay, but you picked the one part of the car that has a hole in it. I must have caught a REALLY big rock at some point, 'cause it looks like someone shot out the headlight. It works, it's just got a hole in the glass. Sure you don't want the rear assemblies? I had just replaced the rear light assembly seals before my g/f killed it .
WRXDrew: Clutch was replaced at ~140000, and it's now at ~168000 so it should be pretty good, only problem is there isn't much of a place to work on it to drop a tranny, it's just sitting out in my apartment complex parking lot, not on stands, and not level either. That, and when they come pick it up, the car should probably be in one piece. Lemme know
Old 04-30-2001, 03:44 PM   #6
GameBoys
Member#: 4653
Talking
Concillian, do you think you can drop me one right side door opener (inside)? My one has a broken spring. Thanks.
GameBoys is offline   Reply With Quote
Old 04-30-2001, 03:45 PM   #7
Iron Man
Member#: 4315
2001 RS coupe
silver/custom
Post
integra parts......get out of here with that $hit.
Iron Man is offline   Reply With Quote
Old 04-30-2001, 04:11 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
Angry
Dude,
What's with the hating? There's a reason he put this in his local forum, as a favour to other locals cuz he's a nice guy. A lot of us I-clubbers still own Hondas or have Honda friends.
BTW, I hope you got a turbo if you are claiming a 210hp RS...
Old 04-30-2001, 04:32 PM   #9
Sin4lly
Guest
Member#:
Post
Concillan: damn, my left front light cover is broken as well. is yours crack all the way?
Old 04-30-2001, 05:37 PM   #10
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Post
Just a hole in the center, it's been like that for about a year. It works fine, just has a hole in it. No cracks that I know of.
Old 04-30-2001, 08:17 PM   #11
Sin4lly
Guest
Member#:
Post
Cool, how much you want for it and when can i pick it up. i'm in hayward. email me [email protected]
Old 05-01-2001, 12:17 AM   #12
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Post
Cool .. otoh, if the 6.5's don't fit in the WRX, doesn't that mean the adaptor isn't the right kind?
Old 05-01-2001, 12:18 AM   #13
Sin4lly
Guest
Member#:
Post
I'll part with the left front headlamp if you don't mind - [email protected]
Old 05-01-2001, 12:24 AM   #14
WRXDrew
Member#: 6194
Post
my buddy could use the clutch and maybe some other *****e, I'll ask him
DREW
WRXDrew is offline   Reply With Quote
Old 05-01-2001, 08:35 PM   #15
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Post
Joe:
I just checked the Integra flanges. No go, without modification at least.
The holes are at the right angles, but just a few millimeters shy of the right radius. A dremel and a few minutes to make at least two out of three of the holes into 'forks', and it should fit okay.
Then, there's some stuff on the back surface, that doesn't fit in the hole, that stuff would have to be dremeled off too.
That should all work, but even then, the spacer may be too thick to fit properly between the door and the door panel.
Old 05-01-2001, 09:34 PM   #16
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Post
Oh Gawd.
Trust Honda and Subaru to come up with the exact same speaker mount style, just with a different diameter.
Thanks much for checking, Concillan. Best of luck parting out that car.
Anyone need any parts from a 1990 Legacy? scoobyimprza Mid Atlantic Impreza Club -- MAIC 38 08-21-2005 12:38 AM
Anyone buy parts from the UK? Chandy69 Tri-State Area Forum 5 05-04-2005 10:20 AM
Anyone ship parts from UK to USA? rB5 General Community 6 10-08-2004 10:26 AM
OT: Anyone want parts from a totaled '91 Cavalier? Siper2 New England Impreza Club Forum -- NESIC 8 01-15-2004 11:32 PM
Anyone need anything from SPO? Saw Jai Bay Area Impreza Club Forum -- BAIC 5 12-21-2000 10:26 PM
