Old 10-23-2000, 04:26 PM   #1
slide
Member#: 1130
2013 STI Hatch
Post Bored throttle body
I finally found the phone number to where i got mine done. TAD motorsports.. 847-550-8116.
About 160 bucks But HP aint cheap.
Sorry for the long wait
slide is offline   Reply With Quote
Old 10-23-2000, 04:39 PM   #2
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
Post
what size did you bore it to?
kid22 is offline   Reply With Quote
Old 10-23-2000, 08:15 PM   #3
slide
Member#: 1130
2013 STI Hatch
Post
Ooh don't quote me... but I belive it came back at 78mm. I will check and post tomorrow.
Old 10-23-2000, 08:28 PM   #4
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
Post
wow, cool, not a bad price too
Old 10-23-2000, 09:31 PM   #5
JaiMak
Top Scoob 004
Member#: 697
1999 Top Scoob #4
Satin White Pearl
Post
78mm sounds like a lot, a shop affiliated with the TO club had 63mm throttle bodies, and the cylinder wall on the body looked pretty thin, I'm pretty sure you'd only be able to bore it out to about 65mm without the walls being paper thin.
Stock size I believe is 60mm.
JaiMak is offline   Reply With Quote
Old 10-24-2000, 04:58 AM   #6
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Question
Was there a reason you overlooked the Cobb Tuning Throttle Body (http://www.cobbtuning.com/impreza/engine-throttlebody.html) even though it's about $90.00 more *not including the core charge*?
Kevin Thomas is offline   Reply With Quote
Old 10-24-2000, 07:43 AM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
...and the results?
Old 10-24-2000, 01:30 PM   #8
JC
Member#: 692
2011 Grand Cherokee
Triumph Speed Triple R
Post
The Cobb throttle body is 64mm.
JC is offline   Reply With Quote
Old 10-24-2000, 01:56 PM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
The OD of the stock throttle body is 2.75" so even if you wanted to keep a 1/8" wall, the bore could only go to 2.5" (63.5mm).
BTW, I'm fairly sure TAD sent it out to be bored... they're more of a garage with lots and lots of cool stuff in it. Some day I'll get up there and take a few pics for those who want to see EVO's and WRX's and stuff apart and all over the place. Last time I was up there we were walking along and I kicked a pallet and looked down. There sat a WRX motor in full splendor.
Old 10-24-2000, 04:00 PM   #10
Pipercub
Member#: 2188
2004 Impreza STI
82 BRAT with 12 in. lift
Post
The operative question is how large is the intake manifold at the point it mates to the TB? If it is larger then it makes sense to open the Tb up but if the opening is the same size as the TB is stock then it seems like you would end up with a turbulence inducing step.
Pipercub is offline   Reply With Quote
Old 10-25-2000, 12:40 AM   #11
slide
Member#: 1130
2013 STI Hatch
Post
Uh the reason the cobb unit was overlooked was that I had it done in 1996 on my 95 2.2l. I am going to get an official measurement today to post.
Old 10-27-2000, 09:55 PM   #12
slide
Member#: 1130
2013 STI Hatch
Post
I had the manifold port matched to the throttle body by extrudehone. Sorry about the delay. I have been at work and will be untill sunday. around 11 am sunday my car will be apaart and Ill have answers.
sorry
Old 10-27-2000, 10:23 PM   #13
Aspen
Member#: 145
Banned to
Housework for Summer
Post
When you say that you had the intake manifold "port matched", are you just referring to the opening of the intake manifold or do you mean taking some metal out of the entire intake runners?
I was thinking of extrudehoning my intake manifold until they quoted me almost $300 for the process. ouch.
Aspen is offline   Reply With Quote
Old 10-28-2000, 08:38 AM   #14
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Post
Throttle? We don' need no steenking throttle! Pop it off and run wide open baby!
Necromancer is offline   Reply With Quote
Old 10-30-2000, 03:59 PM   #15
Buckbomb
Member#: 2573
Post
Sorry to butt in, but would you happen to have a ball park figure on HP gains/ Pick up? It sounds like a good deal if gains are significant.
Buckbomb is offline   Reply With Quote
Old 10-30-2000, 04:06 PM   #16
slide
Member#: 1130
2013 STI Hatch
Post
All I have is abunch of g-tech stuff from a while ago. I never had any baseline tests.
My butt dyno was happy.
Ill do some more runs and plant some numbers. Remember i only have a 2.2l
Old 10-30-2000, 06:13 PM   #17
Kevin Thomas
Member#: 110
1989 1989 XT6
Question
I'm a little confused about all of this. 8Complex says that the stock throttle body is 2.75" (69.85mm). Slide says that the diameter of the intake port on the manifold is 70mm (2.76") and that he had the throttle body 'port matched' to the intake port. This would mean he had his throttle body was ported from 69.85mm to 70mm (or 2.75" to 2.76").
Is this saying that a .01" (or .15mm) ported throttle body is a significant amount to make more horsepower or torque? Is there an faq somewhere that says how much hp/torque you can expect with each inch or mm the throttle body is ported until it's matched with the intake port?
[This message has been edited by Kevin Thomas (edited October 30, 2000).]
Old 10-30-2000, 06:48 PM   #18
slide
Member#: 1130
2013 STI Hatch
Post
You have to remember that mine is a 95 2,2 l and whether or not that resembles your 2.5 stuff. I had to spend a couple minutes trimming the gaskets. The next time I am at a dealership, ill measure a stock one.
Maybe there is nothing you can do to the 2.5l recent TB's. But if there is... getting more air through that bottleneck can't hurt. It's just up to you on if it is cost effective for you. I liked it.
Old 10-30-2000, 10:13 PM   #19
Aspen
Member#: 145
Banned to
Post
Remember when you use the butt dyno on items like lightened flywheels or underdrive pulleys or even bored throttle bodies, not to confuse increased throttle response with horsepower. I see so many people making this mistake.
It is true that increased throttle response can get you a better time at either track and can make your car faster without gaining any extra horses.
Old 10-30-2000, 11:53 PM   #20
slide
Member#: 1130
2013 STI Hatch
Post
Oh I agree 100%, but my butt dyno is responsive to how much throttle I have to put into going up certain hills and keeping consistant speeds on my hour long commute to and from work.
Old 10-31-2000, 12:15 AM   #21
slide
Member#: 1130
2013 STI Hatch
Post
Hey sorry for the delay.... Its 70 mm on the dot. Could probably have gone to 72mm but oh well.
Aspen port matched means the diameter of the throttle body is matched to the diameter of the intake port on the manifold. And they also rmoved material on all the runners Its like glass in there now.
Old 10-31-2000, 12:29 AM   #22
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
Aspen, you can be making horses without increasing the max HP. That TB can increase the HP at the lower RPMs making the the HP/torque curve fatter and improving throttle response.
Imprezer is offline   Reply With Quote
Old 11-01-2000, 12:14 AM   #23
Aspen
Member#: 145
Banned to
Post
yup yup on that Imprezer also. I realize that certain mods can broaden the torque/hp curve or change it at certain rpm ranges.
I was just merely stating that increased throttle response can easily be mixed up with hp.
FS: Ported / Bored throttle body for 02-03 WRX Orbiter Private 'For Sale' Classifieds 13 06-02-2005 07:59 PM
Anyone bore out the throttle body? phatride01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-26-2002 05:54 PM
Again, group throttle body boring?? IBO Vancouver Impreza Club Forum -- VIC 16 06-01-2001 11:19 AM
Group throttle body boring? IBO Vancouver Impreza Club Forum -- VIC 15 05-23-2001 11:08 PM
Bore the throttle body.. jacktam1 Normally Aspirated Powertrain 4 02-13-2001 10:59 AM
