Old 10-29-2000, 08:23 PM   #1
cowboy
Member#: 156
Exclamation smell coming from car after drive...
there is a "burning plastic" type smell coming from my car now when i drive it.... my guess is it has to do with the clutch (although it doesn't feel any different then before) since it started smelling right after i was stuck in traffic trying to pick up friends at the airport ( a lot of '0-10-0mph' for about an hour). i checked all my fluid levels and everything seems fine... no engine lights or anything and it drives completely normal.
any ideas?
[oh, and my car is a 99 w/ 32,000 miles on it and no engine mods.]
cowboy is offline   Reply With Quote
Old 10-29-2000, 09:47 PM   #2
jackwei
Member#: 233
Post
I assume when you start the car moving, you slip the clutch, right? probably just slipping too much in one day...
jackwei is offline   Reply With Quote
Old 10-30-2000, 03:46 AM   #3
2yLiTe
Member#: 660
Post
This topic has puzzled many in the past, and in the end it almost always resulted from a plastic bag that has found it's way to sticking to your exhaust. Have a look under your car and see if there are remnants of burning plastic along your exhaust. If there is, you can expect the smell to go away after a few days (unless you wanna get under there and clean it yourself) This happened to me last year, and I thought I broke my scooby! :P
2yLiTe is offline   Reply With Quote
Old 10-30-2000, 06:49 AM   #4
HKK
Member#: 298
2000 Impreza 2.5RS
Post
I had a similar burning smell and it turned out to be grease/transmission oil leaking from the driver's side front transaxle onto the exhaust pipe. Someone mentioned it might be the axel seals gone bad. Anybody else have this problem?
HKK is offline   Reply With Quote
Old 10-30-2000, 07:46 AM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
I had issues w/Axle grease once... stock grease was too thin and was leaking onto the exhaust - causing the burning smell... there was a dealer recall...
could be tranny fluid?? as well???
of course, I still have that problem
Old 10-30-2000, 09:08 AM   #6
cowboy
Member#: 156
Post
ahh... plastic bag... i think i remember running over one and not seeing it behind me. i hope that's it.
thanks guys.
Old 10-30-2000, 04:09 PM   #7
gs9k
Member#: 2477
Post
i had the same burning-plastic smell too. first i thought it was my clutch, but turns out there was a melted plastic bag stuck to the exhaust piping. this was last week and i still have that smell, even after scraping off as much plastic as i could. could be just the remaining bits being burned off or something else, like my clutch after all.. let us know what you came up with. -g
gs9k is offline   Reply With Quote
Weird smell from AC after driving hard 07 sti 4sevens Interior & Exterior Modification 4 04-30-2007 10:53 AM
Strange smell coming from the car Andrew Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 01-31-2007 06:38 PM
Gas Smell coming from car? Notyab Service & Maintenance 2 12-02-2005 07:30 PM
Smell coming from car. DaveA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-14-2004 12:55 AM
Oh no, what is this smell coming from the car? ImprezedRS South East Region Forum 7 09-04-2001 02:15 PM
