Old 07-06-2004, 03:46 PM   #1
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Default Figure this one out
Between 3500rpm and 4000rpm the engine will hesitate heavily. I have tried tuning the problem out (fuel/timing). I checked the wiring, vacum lines, and I have tried different injectors. I have also noticed that if I am cruising in that range the tach will wobble very slowly. After examining the datalogs I have noticed that the a/f ratio will go lean by about 2 points during this range, so I richened up the mix only to find that the hesitation is worse. After a year of trying to solve the problem on my own I have managed to smooth the problem down to the effect of a slight jolt, but I would love to get rid of it completely.
The only thing that works is to set the injector firing from sequential to group. In group mode the engine revs so smoothly, but I loose about 3-5 mpg. Group mode also smooths out the a/f ratio across the board.
I also have noticed much like a few other people that between 2000-2500rpm during light cruise the engine bucks slightly.
Has anyone solved either of these problems?
-Chav
Chav is offline   Reply With Quote
Old 07-06-2004, 03:50 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
what fuel pump and reg r u runnin?
Old 07-06-2004, 03:58 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
You might be running too rich in the midrange there instead of too lean.
That is the problem with an A/F meter... you can never tell on odd situations like that. See, with too much fuel the engine will misfire and just blow it out the tailpipe. The A/F meter just sees the air go by and reads real lean instead of real rich like it actually is. I've run into that problem before, and it's frustrating as hell until you get the cahones to lean it out a bit.
Old 07-06-2004, 04:11 PM   #4
Chav
Member#: 3269
RSTi
walboro (Ludespeed stage 2) with stock reg and parallel fuel lines.
8complex, I tried that as well. I smoothed out pretty well up until it started pinging at around 13:1 a/f (wideband). So I richened it back up in favor of the hesitation rather than nuking a piston.
A lot of the normal tuning thoughts to solve this problem would make sense if the problem didn't completely go away when group injection is selected.
-Chav
Old 07-08-2004, 08:20 PM   #5
Chav
Member#: 3269
RSTi
Well I tried disconnecting the ribon (laptop connection cable) from the link plus (thinking it maybe an interferance problem), but that didnt help at all. Next I'm going to try hard wiring the fuel pump. If that doesnt work I'm going to wire it up to use antiphase group injector firing and hope for the best.
-Chav
Old 07-09-2004, 01:44 AM   #6
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
How long is your vacuum line running to the link. When i shortened mine up it cleared up a lot of the hesitation. Are you using map+tps?
Drac9 is offline   Reply With Quote
Old 07-09-2004, 03:25 PM   #7
Chav
Member#: 3269
RSTi
I have a gm map sensor in the engine compartment. Before I had a pretty long line going from the link to the engine, and thought that if I had a closer sensor it would improve response. It helped a bit, but it didnt do anything for the hesitation. I'm running map fuel schedualing because with map + tps sometimes with sudden throttle movements into boost the link wouldnt change timing fast enough and the engine would ping.
-Chav
Old 07-09-2004, 06:06 PM   #8
RyansJDMgc8
Member#: 65462
01' 2.5RS
Silver/Carbon Fiber
Bad o2 sensor?
RyansJDMgc8 is offline   Reply With Quote
Old 07-11-2004, 01:55 PM   #9
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Hmm... how many pounds of boost are you running? I see you have an '01 so you are on the SOHC heads. Try dropping the gap on your plugs. As strange as it sounds, some people have issues with the plug firing getting blown out at those engine speeds at certain boost levels. FHI designed those cams to create LOTS of turbulence at cruising speeds to improve fuel economy. When your radically increase your flow velocity the RPM's in which this effect happens moves up. The increased flow velocity makes the turbulence get REALLY crazy. The fact that batch firing smooths things out a bit also makes me think this is the issue.
anyway... I've gone on long enough, try dropping your plug gap to something in the range of .025 and see what happens.
no-coast-punk is offline   Reply With Quote
Old 07-11-2004, 02:04 PM   #10
Chav
Member#: 3269
RSTi
no-coast-punk, i'm running 5psi in the mid-range and up to 8psi up top. Originally I had my gap at .40, after the hesitation I moved it down to .30. I will try to move it down to .25 and see what happens.
Thanks for the reply.
-Chav
Old 07-11-2004, 09:40 PM   #11
Chav
Member#: 3269
RSTi
Down to .25 with no improvement.
-Chav
Old 07-12-2004, 12:24 AM   #12
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
What is your setup?
Old 07-12-2004, 12:26 AM   #13
Chav
Member#: 3269
RSTi
ludespeed stage 2, 440 rc injectors, link plus, borla 2.5 inch cat back, borla headers, and the normal stuff like fuel pump, dual feed fuel lines that came with the kit.
-Chav
i cant figure this one out..... turbo'98L Normally Aspirated with bolt-on Forced Induction Powertrain 3 03-15-2007 02:37 PM
ej18+ej20g+ej20K powerFC. crazy idea. i wonder if anyone has figured this one out. stupidguy Subaru Conversions 6 05-11-2006 03:37 PM
Some body figure this one out. (element/hydra ?) trail*of*dead Other Engine Management 8 02-06-2005 02:58 PM
see if you guys could figure this one out rsfreak Mid West Subaru Owners Club Forum -- MWSOC 3 04-01-2002 04:46 AM
Someone want to help me figure this one out?... wrx182 General Community 4 11-29-2001 10:12 PM
