Old 07-06-2004, 03:26 PM   #1
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Default Need hubcentric spacer.
I have a '98 RS with rota slipstreams. They are rubbing my struts. What is the biggest hubcentric spacer I could get with keeping the OEM lugs.
I contacted [email protected] and he gave me no help. Just, "we don't reccomend spacers"
KEVIN
FatCatTurbo is offline   Reply With Quote
Old 07-06-2004, 11:02 PM   #2
rota wheels wrx
Member#: 13856
04/5 STI
white/WRB
It really depends how long the studs are in your car. I have seen some Subarus with longer studs than others so it's hard to tell. To be on the safe side, I would say 3mm.
Remember, you must have at least 12mm of thread enagement left for the nuts to work properly.
What is more puzzling to me is why they are rubbing on your car since the offset on the slips is 48 and I have seen GC8s run as much as 53 offset on the same size wheel without problems
rota wheels wrx is offline   Reply With Quote
Old 07-06-2004, 11:20 PM   #3
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
I am running a pretty big tire. Where would I be able to get something like that? Can I get a all in one spacer that is hubcentric? Or would I need to get the 3mm spacer, then get a hubcentric ring?
KEVIN
Old 07-07-2004, 02:57 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
With a 3mm and less spacer you probably aren't going to find one that's hubcentric and likely don't need one since the wheel will still be hubcentric on the hub. You want to use hubcentric spacers if for some reason the wheel can no longer sit on the hub and be hubcentric itself. If you use 10mm+ spacers on a WRX that will happen. Tirerack does have 5mm hubcentric spacers but you can't use that without going to longer wheel studs.
*sold*H&R 25mm hubcentric spacers 5x100 lakai5 SCIC Private Classifieds 14 06-03-2010 07:39 PM
WTB: 3mm 5x100 hubcentric spacers (4) 05ASPINREX NESIC Private Classifieds 2 04-19-2010 04:47 PM
FS: LA, CA - Custom 5mm Hubcentric Spacers Drag-On Wheels/Tires 13 11-11-2009 01:39 PM
WTB: Hubcentric Spacers 5mm and 10mm w/ studs jimbo15471 Private 'Wanted' Classifieds 0 05-01-2008 09:49 PM
Are hubcentric spacers needed for Superleggeras? Zuffy Tire & Wheel 10 06-16-2003 07:39 PM
