Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 10-28-2000, 10:24 AM   #1
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
Question Question about viscous limited-slip
Ok, i've read that a viscous slip diff uses plates and fluids to function. so, basically, isn't this just like throwing a slushbox automatic tranny in the car? or are these much more responsive than a torque converter? or does the auto tranny seem sluggish just cause of the way it shifts (meaning it's not the torque converter at all)? i will say, i haven't driven an auto RS, but i do know how they feel in other cars...
JGard is offline   Reply With Quote
Old 10-28-2000, 10:49 AM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
A torque converter is more complex than a viscous coupling, car manufactureres a long time ago used viscous couplings b4 tourqe conversters were invented, but they found they overheated to easliy.
Get a book about auto trannies and youll get a good description on the two.
Jay McDade
MY00 BRP RS coupe
auto tech
Old 10-28-2000, 10:52 AM   #3
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
Post
i understand that it is more complicated, but my question was about the "slushiness" of both the torque converter and the viscous coupling, since they are using the viscosity of liquid to turn plates (essentially)...
[This message has been edited by JGard18 (edited October 28, 2000).]
Old 10-28-2000, 02:01 PM   #4
Jay_UK
Member#: 296
Post
In theory no (once the plates have locked)
Otherwise you will fry the fluid.
There will be some slip/loss at first.. this lost energy/power goes into heating the fluid.
Hence the viscous diff isnt instantly acting.. there is a slight deal (slushiness?)
J.
Jay_UK is offline   Reply With Quote
Old 10-28-2000, 02:03 PM   #5
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
Post
ok, that much makes sense... like, about the locking and such. but what about while driving, and it has to lose some power from one end of the car to the other? cause then they won't be able to spin at the same speeds, correct? or am i missing the point on that one?
Old 10-28-2000, 02:16 PM   #6
Kwez
Member#: 1467
Post
1st of all sorry if I offended anyone (I'll use the "I'm french" excuse again here;-), I'm just trying to understand too !
2nd, I'm not sure on the details, but don't we have some direct connection from the trans to the wheels (ie front wheels), so at worst it would be just like a manual front wheel drive car w. some power loss from the center diff ? So we would not feel the slugginess since it would be just between the front / rear wheels under slippery conditions ?
Keep smiling
Philippe
Kwez is offline   Reply With Quote
Old 10-28-2000, 02:17 PM   #7
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
Post
see, i thought the center diff. was the same concept as a transfer case. where the tranny went to that, and then split out to front and rear. but am i wrong again?
Old 10-29-2000, 12:28 AM   #8
Nat
Member#: 759
2004 WRX
2000 SV650
Post
It's not the viscosity of the fluid that determines auto tranny shifting, but pressure. Most shift kits are used to modify the pressure that the shifting mechanism sees so that shifts are quicker and harder. The center diff on our cars are different in that it relys on the viscosity of the fliud to "lock" up. When the plates (F vs R) rotate at different speeds, it causes the fluid to get thick and therefore transmit power to the rear.
Nat is offline   Reply With Quote
Old 10-29-2000, 12:28 AM   #9
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
It's totally different. In a viscous limited slip, the fluid that is used has the unusual property in that it "stiffens" up (get your minds oout of the gutter) when it gets hot - and it is this property that is used to make the plates rotate and perform the limted slip function. A torque converter uses conventional oil to build pressure to make the tranny work.
rao is offline   Reply With Quote
Old 10-29-2000, 12:31 AM   #10
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
Post
ahh, thanks, that's basically what i was looking for.
Old 10-29-2000, 12:44 AM   #11
Kwez
Member#: 1467
Post
can someone explain this to me ?
I always thought that 'viscous limited-slip' was for 'torque transfer' in differentials (left to right or front/back for AWD), so how does that have anything to do with a slushbox? After all we DO have a viscous diff for the AWD .. right ? And there's no sluggish auto tranny feel to my 5spd RS.
(hehe maybe it's because i'm french, i'm loosing a nuance in the question or something ;-)
Thanks
Curious Kwez
Old 10-29-2000, 12:47 AM   #12
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
Post
i'm basically curious as to if there's any power loss in the center diff. because it uses fluid (a la auto tranny) in order to move one set of plates to another. apparently though, it's oil in the torque converter, but same idea (almost). not to be a jerk, but do you know exactly how a viscous diff. works?
Old 10-29-2000, 09:04 PM   #13
Kwez
Member#: 1467
Post
hmmm, you could be right...
hey you super subie tuner guys out there, someone must know the details on this !!
Old 10-30-2000, 09:12 AM   #14
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Post
The way I understand it:
Tranny delivers power to the center diff, splits front and back
the back is split by the rear diff
same for the front.
the LSD's(center and rear? I know it's at least rear, and wouldn't make sense w/o the center otherwise the power would just go to the front) transmit power w/o using the viscous fluid normally. Only when one wheel starts to spin faster does it heat the fluid and make the other wheel spin the same speed. This is why it doesn't feel slushy. I really don't understand the exact mechanics, but from everything I've read, this is how it works. Trey's done alot of work w/ the system(AWD to RWD), maybe we should ask him...
mrbell is offline   Reply With Quote
stability control with viscous limited slip center diff Beanboy Newbies & FAQs 0 04-17-2006 12:12 AM
Limited slip viscous coupling rear differential swap into a '99 Impreza. powerlabs Subaru Conversions 11 04-25-2004 11:41 PM
viscous limited-slip rear differential? isn't this inherent in AWD? ufoguy Transmission (AT/MT) & Driveline 9 12-01-2003 10:27 PM
what is viscous limited-slip rear differential? count26 Newbies & FAQs 4 05-10-2003 06:26 AM
Viscous limited-slip diff. question SubaruImpreza_power Transmission (AT/MT) & Driveline 6 05-28-2002 01:53 PM
