Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 07-06-2004, 05:24 PM   #1
WRXinEffect
Member#: 19392
2006 Forester XT
Steel Gray
Question What is the sign of an imbalanced wheel/tire?
Just wondering what the noticeable symptoms would be of an imbalanced wheel/tire combo. I just picked up a set of new wheels/tires and noticed that one of the stick on weights appeared to have fallen off. I can't tell, but they either fell off or were moved. Anyway, just want to know what to look for...
WRXinEffect is offline   Reply With Quote
Old 07-06-2004, 05:43 PM   #2
ripvw
Member#: 27790
according to Tire Rack:
If you have a vibration that is dependent on speed, and usually becomes noticeable around 40-45 mph and increases as your speed increases, it's probably balance related.
they have a pretty nice chart for diagnosing vibrations:
http://www.tirerack.com/images/tires/vibechart.pdf
In any case, I would go to a good alignment tech and have them rebalance that wheel
ripvw is offline   Reply With Quote
Old 07-06-2004, 06:06 PM   #3
Rally1
Member#: 20633
Just after new tires, when I got up 75mph the car would shake, one rear wheel was out of balance. If the steering wheel had vibrated it would suggest a front out of balance.
Took it back to the shop and had a rebalance.
edit:
Cool
Rally1 is offline   Reply With Quote
Old 07-06-2004, 11:37 PM   #4
BlkTS02
Member#: 50142
2002 2.5TS
MBP
I've had a vibration appear at around 62mph, then it vanished when I got above 75. After getting my tires balanced it never came back.
BlkTS02 is offline   Reply With Quote
Old 07-07-2004, 10:31 AM   #5
Boxologist
Member#: 21118
have a friend follow when ur driving and look at yr wheels. very obvious to them.
Boxologist is offline   Reply With Quote
Old 07-08-2004, 08:05 AM   #6
ascott
Member#: 6545
Rally Blue Pearl
Ummm, no.
ascott is offline   Reply With Quote
What is the sign of worn out engine mount? WRXVII Service & Maintenance 3 02-08-2004 03:13 PM
what is the benefit of an adjustable Volt Clamp akcel Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-16-2002 04:07 PM
what is the going rate for wrx wheels/tires? Benjamin Tang Vancouver Impreza Club Forum -- VIC 23 06-10-2002 12:37 AM
What is the purpose of an oil pressure gauge? redobs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-01-2002 12:59 AM
What is the purpose of an angled top mount intercooler? latinskllz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-10-2001 10:07 PM
