Old 07-06-2004, 05:42 PM   #1
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
Default Boosted 4EAT Guys
I know there are some of you guys out there...
I was wondering if just a tranny cooler would be suffiecient in protecting my 4EAT at 4-5 lbs of boost and probably 60% increase in Torque (Just a guess)?
I know about the valve body stuff... but i'm not looking for crazy transmission performance. I just want to make sure my 4EAT with a tranny cooler and good fluid would be fine at 4-5lbs. (Tranny has about 60k miles on it.)
Do any of you have a similiar boosted set up on your 4EAT?
D-Speed 2.5 is offline   Reply With Quote
Old 07-06-2004, 06:47 PM   #2
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
Anyone out there? I would have posted in the transmission forum but since this is specific to a boosted EJ25 i'm gunna leave it in here.
Old 07-06-2004, 09:51 PM   #3
inpreza kid
Member#: 3334
your fine at 4-5lbs. you shouldn't have any problems until you go over 10psi.
inpreza kid is offline   Reply With Quote
Old 07-06-2004, 10:24 PM   #4
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
You should be fine as long as you don't do any heavy track events or so, and even then, you're in Colorado!
Wedge is offline   Reply With Quote
Old 07-07-2004, 12:34 AM   #5
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Make sure you have a upgraded cooling system and check your fluids. You should be alright for a mild boost setup.
DoctorNick is offline   Reply With Quote
Old 07-07-2004, 12:39 AM   #6
yzracer758
Member#: 59938
2009 MB C300
Subiesport Featured GC8
I've ran as much as 7lbs. of boost on my complete stock auto and it has ran fine.
yzracer758 is offline   Reply With Quote
Old 07-07-2004, 01:52 AM   #7
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
I have an ej22T on my 95 auto, its doing fine.
subiekid is offline   Reply With Quote
Old 07-07-2004, 10:19 AM   #8
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
Cool thanks. I need the tranny cooler anyways b/c I do a lot of mountain driving. I will be adding a good tranny cooler and new fluids. Thanks for all the help. Once done, I'll post an update on the boosted 4EAT EJ25.
Old 07-07-2004, 03:37 PM   #9
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
I also have a boosted EJ25 AT. I am using a small Trans cooler in front of the radiator. I also used the factory performance gauge pack's oil temp gauge to monitor Trans temps and rarely see over 70C, 80-85C in bumper to bumper traffic on the hottest of South Florida days. I am only boosting 3.5psi though but I am sure 5psi is fine. (My wastegate has the .25bar spring)
ForesterPerformance is offline   Reply With Quote
Old 07-07-2004, 04:48 PM   #10
subiekid
Member#: 25516
Did the temp sensor for the gauge pack fit right into the trany? Where is the sensor mounted?
Also, are any of you guys woried about having long lines for your trany cooler? I was trying to think of places that it could be mounted closer to the trany so that the lines are not so long.
Old 07-11-2004, 02:32 AM   #11
Joncas
Member#: 5349
I was boosted for almost 40,000 miles with a supercharger. That meant alot of torque stress on launches. I used a Hayden 403 tranmission cooler and mobil one synthetic atf. The lines ran from the drivers side of my engine bay to 3/4 of the passenger side of the radiator where the cooler is mounted. The car went though an accident in which the radiator had to be replaced and the hayden showed no damage at all. I'm no longer boosted but when I stopped around 100,000 miles the car shifted just fine. It now has 102,000 on it and the tranmission is still tight.
my 2 cents.
Joncas is offline   Reply With Quote
Old 07-11-2004, 03:05 AM   #12
import111
Member#: 24447
2010 Evo GSR
GG
All the positive feedback on the 4EAT is very good to hear. I have been turboed for about 3 weeks. I drive my car very hard so it makes me feel better hearing all the good responses about the 4EAT.
Ryan
import111 is offline   Reply With Quote
Old 07-11-2004, 03:52 PM   #13
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
The 4eat is a pretty stout unit. With a good cooler and fluid they're nice and reliable up to about 10lbs. If you don't get your temps too hot and keep a very close eye out for any slipping you'll be fine.
no-coast-punk is offline   Reply With Quote
Old 07-12-2004, 10:42 AM   #14
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
Thanks again for all the response. I am pleased to hear that I should be good to go on a Tranny Cooler an good Fluid. Boost here we come!
Old 07-12-2004, 07:25 PM   #15
subiekid
Member#: 25516
my 2 cents.
Do you have some pictures of the unit mounted?
Thanks
Old 07-13-2004, 05:48 PM   #16
3BadHabbits
Member#: 38011
2005 05FXT-RICE!!!
Silver RICE!!!
The 4EAT is probably one of the strongest that subaru makes.
Just Ask These Guys:
http://www.rigoliracing.com.au/
3BadHabbits is offline   Reply With Quote
Old 07-24-2004, 08:50 PM   #17
subiekid
Member#: 25516
Has anyone had problems running some type of aftermarket ecu and the 4eat?
I am tuning my tec and when I take the car our of park it goes into a lean condition and stalls.
Old 07-25-2004, 01:39 PM   #18
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
I got a chance to talk with Easy Street when they were in town last. They're 4eat used straight cut gears. I'm not sure if it still uses a ratchet type shifter or not. I'd love to be able to click through really tough gears THAT easily, even if gear whine was an issue. They were NOT cheap, though. Oh well...hope my stock tranny holds with the new blower.
HamFist is offline   Reply With Quote
Old 07-27-2004, 12:07 PM   #19
Joncas
Member#: 5349
I don't have any pictures of my piping and stuff but if it ever stops raining here in NY I'll snap a few shots.
Here are the possible problems I've encountered with the 4eat. Each is fairly insignificant.
1. On MAF equipped if you happen to unplug the MAF or the MAF should get drenched in water the Transmission light will come on and flash. Owners manual says that you need to turn your car into the dealer immediately along with your check book. No - worries, normal condition.
2. If the transmission doesn't get a proper TPS signal then it gets upset. Therefore those of you running a J&S safeguard (ultra safeguard model) shouldn't hook up the TPS signal if you are using the J&S under boost. It will cause the tranmission to downshift everytime you hit boost if it is within a safe RPM range to do so. - VERY annoying but its nothing having to with the J&S, it's the way the TCU works.
Old 07-27-2004, 04:42 PM   #20
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Hrrmm, that would seem like it would be an advantage speed wise. I can understand it being annoying though for someone just driving around. I think I'd like this though.
Kevin Thomas is offline   Reply With Quote
Old 07-27-2004, 04:55 PM   #21
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
where on the tranny did you guys plug in your tranny temp sensor for the gauge?
2.5 Blue Roo is offline   Reply With Quote
Old 07-28-2004, 12:21 PM   #22
D-Speed 2.5
Member#: 29516
2005 WRX Wagon
Former GC O.G.
Just received my Hayden 403. Awesome little unit!
Old 07-28-2004, 10:38 PM   #23
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
man you guys must have different TCU code or somthing, or it must be the extra couple hundred pounds of my car cause i was slipping at 6psi on my 4EAT
good to hear you guys are having no probs though. i decided to upgrade
Ben
Old 07-29-2004, 01:35 PM   #24
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
I used the Factory Performance Gauge Pack's Oil Temp Gauge (since it just says TEMP not OIL TEMP). The Oil Pan drainplug and the Tranny Pan drainplug are identical, so you can just use the sending unit-plug in the tranny.
Or, you could remove the pan, drill it and tap it for the Autometer sending unit and use it... Since I got a second-hand Gauge Pack (thanks Wedge) for free, this was the way I went...
FWIW: all-subaru.com has the black-faced performance gauge packs on clearance for less than $200.
Quick Q's for the 4EAT guys WITH Tranny Coolers lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-12-2006 09:36 PM
4EAT Guys....need a favor. Shift lock noise from dash? Alan l. General Community 3 02-28-2006 12:16 PM
4EAT guys w/ aftermarket trans coolers... Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-26-2004 06:38 PM
Who are the 4EAT guys from so cali or orange county showcasewrx Southern California Impreza Club Forum -- SCIC 6 12-09-2003 06:20 PM
4EAT guys... how much wheel horsepower? roninwarior007 Transmission (AT/MT) & Driveline 24 07-18-2003 03:16 PM
