Old 10-27-2000, 08:58 AM   #1
Gambit
Member#: 102
Post reseting the ecu ....fuse method
Hey,
A few questions.
1) which fuse does the ecu reset?
2) when you put back the fuse will it set the alrm off?
3) will it clear all the clock and CD deck settings? (ie full reset like the battery terminal method)
Gambit is offline   Reply With Quote
Old 10-27-2000, 09:51 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Post
sfb2.. under the hood.. does not work for 2000s
remeber sanfranciscobay2
-j
Old 10-27-2000, 09:52 AM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Ah ha, that explains why I couldn't find that fuse in my MY00...
RidinLow is offline   Reply With Quote
Old 10-27-2000, 10:04 AM   #4
DuneHopper
Member#: 1249
2000 OBS
Thumbs up
Actually, the MY00 stereo maintains its presets if the battery isn't disconnected for much longer than a half hour. The clocks still need to be reset.
And I still jump out of my skin when the alarm goes off upon reconnecting the battery, even though I'm ready for it and I have the button in my hand.
DuneHopper is offline   Reply With Quote
Old 10-27-2000, 10:48 AM   #5
Gambit
Member#: 102
Post
roger that. but would like to hear the non MY00 weirdo Imprezas speak up.
Old 10-27-2000, 11:40 AM   #6
Ken S
Member#: 1895
05 Leg GT Ltd. W
Post
I don't think the fuse method works on my 98. I've left it pulled overnight but when I start the engine it starts up like nothing ever happened. Fuel milage afterwards stays the same too.
On the other hand, when I unplugg the battery terminal, there is a noticeable difference in idle and engine behavior at startup. Gas milage dips initally, then climbs back up.
Also, radio presets don't change after battery disconnect. Only the clock needs to be reset.
For those of you who have the alarm, try stuffing the alarm horn with a towel -- it reduces the "heart-attack" factor.
Ken S is offline   Reply With Quote
Old 10-27-2000, 12:02 PM   #7
Gambit
Member#: 102
Post
Well the battery method resets everything including my stereo presets. All it takes is leaving it off at 30+ minutes and everything's gone.
Old 10-27-2000, 02:04 PM   #8
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
On my 99 with aftermarket stereo, hooked up via proper wiring harness,i loose ALL my settings. I will have to try the fuse method soon.
STiShawn is offline   Reply With Quote
Old 10-29-2000, 12:40 AM   #9
P.K. Motorsports
Member#: 1110
1999 RS
Post
The fuse method doesn't consistently work. When you have an A/F ratio gauge you can plainly see whether the ECU was reset or not, and the pulled fuse doesn't work about 2/3 of the time when left overnight. On the other hand, disconnecting the negative battery cable works after only 10 minutes, and probably in less time than that.
P.K. Motorsports is offline   Reply With Quote
Is it time to Reset the ECU now after the HKS Full exhaust system starBug Transmission (AT/MT) & Driveline 0 07-26-2004 03:12 PM
does reseting the ECU clear the boost numbers stored in there? dijay Warranty Issues & SOA Problems 3 09-03-2002 10:41 AM
Can't find the plugs to reset the ECU. Where? Blitzer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-16-2002 08:48 PM
Which is the correct way to reset the ECU?? z28dan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-26-2002 08:15 PM
Does it needed to reset the ECU for the following changes? V6 Normally Aspirated Powertrain 5 10-27-2000 10:32 AM
