Old 01-22-2001, 09:50 AM   #1
Jessie James
Member#: 2072
Question 2.2l turbo block and 2.5l heads
I've seen it done before (haven't we all) but I would like to know...
1. What head gasket does one use?
2. What intake manifold does one use?
3. What exhaust does one use?
It would be cool to use the turbo 2.2 block and n/a 2.5 heads using the 2.5 intake, but retain the 2.2 exhaust. You think?
Let me know folks...
Mac
Jessie James is offline   Reply With Quote
Old 01-22-2001, 03:24 PM   #2
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
Post
you would want to use the 2.2 head gasket the heads from the 2.5 you would want to use the 2.5 manifold if thats what you have. you can use the exhaust from either since the exhaust manifols are in the same place on both just depends on how you are using the turbo. your CR is going to be quite different should be lowered even further, depends on which 2.5 heads you are going with personally i would get the dohc and a set of cams from trey and spin it to 8000rpm if your turbo and fuel management can support that.
bill harvey is offline   Reply With Quote
Old 01-22-2001, 03:27 PM   #3
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Post
Trey doesn't have DOHC cams yet... you'd also need to get some other wokr done to get 8000rpm... you could probably get at least 7000rpm tho
mrbell is offline   Reply With Quote
Old 01-22-2001, 03:31 PM   #4
Jessie James
Member#: 2072
Post
How much do you think/guess I'll lose on the compression ratio?
It normally runs something like 8.51:1 on the EJ22, and, what, 10.5:1 on the EJ25?
Old 01-22-2001, 03:46 PM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
The Legacy Turbo EJ22 is in fact 8.0:1 and the 2.5L DOHC heads have a larger combustion chamber than the heads that come with the legacy turbo so you'll be under 8:1 for sure. How much under? Ask Trey Cobb.
This compression ratio might be fine for a really high boost effort, but IMO it's too low for anything else.
ColinL is offline   Reply With Quote
Old 01-22-2001, 03:49 PM   #6
Jessie James
Member#: 2072
Post
Thanks for the info - I'll ask Trey.
Mac
Old 01-23-2001, 09:02 AM   #7
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Talk to Dale Teagues, he is doing thas as we speak.
STiShawn is offline   Reply With Quote
Old 01-23-2001, 09:08 AM   #8
Jessie James
Member#: 2072
Post
Dale of Teagues auto supply web site? Is that the guy?
Thanks,
Mac
Old 01-23-2001, 01:11 PM   #9
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
I've talked to trey about strengthing the DOHC 2.5 liter heads. He can do it and he can design cams for whatever aplication you want right there on the spot. Your lookinf between 2500-3200 for full headwork. thats about 3 times as much as a brand new EJ22T shortblock.
Just make usure you get post 96 DOHC heads because the older ones don't fit the EJ22T. The DOHC heads are really hard to find for some reason, but I will not give up.
Your can get 300 dollar a pair hads if you don't care about condition. You basically want the valve cover and head casing. Everything else Trey can fix or put in better parts.
The phase II 2.5L SOHC will fit but sith some adjusting.
WRXwannbe is offline   Reply With Quote
Old 01-23-2001, 01:47 PM   #10
Jessie James
Member#: 2072
Post
So you are saying the 2000 SOHC heads from my MY00 Impreza will fit the EJ22T block, right?
I figure I'll just use them, along with the intake, to make life easier. Of course, it won't be easy but I sure like to fool myself into thinking so!
Mac
Old 01-23-2001, 07:27 PM   #11
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
the 2000 heads will fit but not without modifications. You might want to ask around for detail on this.
Old 01-23-2001, 07:48 PM   #12
Jessie James
Member#: 2072
Question
Would you happen to know roughly what mods are needed?
Mac
Old 01-23-2001, 08:34 PM   #13
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Post
I really don't want to send you adrift on this, because I myself am not consentrating on using the Phase II 2.5 L SOHC, I believe MYPREZA has some info on that, you can even talke to trey about them.
N/A setup with a 2.2L block and 1.8L heads (reliability questions) KillerBumbleBee Normally Aspirated Powertrain 4 08-24-2012 03:02 PM
anyone destroked a 2.2l turbo motor to 2.0 l? HighWayDrifter Subaru Conversions 38 07-05-2010 09:39 PM
2.2l closed deck vs 2.5l STI semi-closed deck 2.5rsDOHC Normally Aspirated with bolt-on Forced Induction Powertrain 27 09-01-2004 03:55 PM
2.2l legacy engine and 2.5l RS engine jetfan8178 Service & Maintenance 10 04-02-2002 05:47 AM
anyone know the CR for the 2.2L Turbo heads? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 7 09-21-2001 09:24 PM
