Welcome to the North American Subaru Impreza Owners Club Monday December 5, 2016
Old 10-27-2000, 08:18 AM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Post SAFC or a RRFPR ? with a turbo
Which one am I better off getting for the tuning of my turbo. My understanding of them is that the both do basicly the same thing but I could be wrong. Some help would be appreciated.
Joshua
MY98 RS
Subaru Salesman
yebokmj is offline   Reply With Quote
Old 10-27-2000, 09:58 AM   #2
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
After installing a RRFPR, I was able to change all my S-AFC settings to 0% correction! The AFC works, but only up to a point because the injectors will go static quickly. With the RRFPR, the increased fuel pressure will increase the "flow" of fuel through the injector without requiring the injector to be open longer.
If anything, with the RRFPR, you might want the AFC to correct down instead of up.
SteveS is offline   Reply With Quote
Old 10-27-2000, 10:19 AM   #3
adam99rs
Member#: 20
Post
same here....I only put minimal changes into my AFC, and even then, only above 4400 rpm. It is nice to have though for the O2 voltage, which was a main reason why I got it.
adam99rs is offline   Reply With Quote
Old 10-28-2000, 01:32 AM   #4
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
2015 Forester XT, Tribeca
Post
This will sound stoopid, but how do I use my AFC to get O2 sensor voltage? I have a MY00 and it may be wired differently than the older ones, since the front O2 sensor is a 5V one. I'll also as JC Sports while I'm there tomorrow.
I am looking forward to my RRFPR, and feel that it will be much more help than my AFC. I am using a plain fuel pressure regulator, and can see the changes it makes if I jack up pressure or lower it.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 10-28-2000, 05:58 AM   #5
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
Larry ~~ FWIW, I'm not using the S-AFC to monitor O<sub>2</sub> readings, I'm using a Jumptronix A/F meter. It's basically a self-contained voltmeter. I'm not positive, but I would think it would work with the wide band sensors on the MY00. If you go to http://www.jumptronix.com I'm sure you'll find the Alex's email address to ask him.
Anyhow, Adam is referring to the "blue wire mod" for monitoring the O<sub>2</sub> readings on the AFC. There is a blue wire which can be hooked up so that you can see the sensor readings while in sensor check mode on the AFC. It works, but it's not very convenient, IMO. (Of course, I now have my AFC in the glove box, so that makes it even worse.)
Steve
Old 10-28-2000, 12:58 PM   #6
shiv
Member#: 607
Post
I would suggest not giving too much credence to o2 sensor voltage (even from a wide-band unit) when tuning a high output turbo car. It's not a very good indicator of air/fuel ratio. It's very dependant on EGT, rpm, ignition advance, etc,. More often than not, it can lead you away from where you want to be. Without the use of a dyno, I would suggest relying on a good set of ears and EGT. The o2 sensor will tell you if you are waaay off in fueling. But so will your butt. YMMV, of course.
Shiv
shiv is offline   Reply With Quote
Old 10-28-2000, 06:06 PM   #7
cakagan
Member#: 251
1998 Impreza 2.5 RS
Question
What does RRFPR stand for?
Thanks,
-Chris
cakagan is offline   Reply With Quote
Old 10-28-2000, 08:28 PM   #8
Rubasu
Member#: 1418
MY00 2.5RS
Post
Rising
Rate
Fuel
Pressure
Riser
Rubasu is offline   Reply With Quote
Old 10-29-2000, 01:31 AM   #9
Kwez
Member#: 1467
Post
hmm, interesting topic guys.
I have a rrfpr w. the Rimmer setup, & I'm not too crazy about it : it seems to be too 'gross' (sp?) of a tuning solution ... It's either: run too rich most of the time or too lean w. detonation at partial boost at higher rpms.
To avoid detonation it's currently set up to run rich. (I also use 94 octane fuel)
I'm still considering a TecII .. but all the 'leaves' (;-) fell off of my money tree (it's automn after all) & I'm a bit worried about the tuning part.
I'm not conviced that the std ITC / AFC combo could fix my problems, any ideas on that ?
(again, the prob is high rpms, w. partial boost : lower boost = lower fuel pressure = higher EGTs ... "popety pop")
Have a nice week-end
Philippe
Kwez is offline   Reply With Quote
who has or is running a RRFPR with there turbo set up witte1919 Normally Aspirated with bolt-on Forced Induction Powertrain 6 07-02-2008 02:19 AM
Benefit of SAFC or EBC with UTEC? KitchenerWRX Newbies & FAQs 6 11-09-2005 12:40 PM
Sti with 20 G Turbo.. Can it take or keep up with 911 Turbo zigger Proven Power Bragging 105 05-14-2005 12:54 AM
Short ram or Cold air with stock turbo? DeezNutz1833 Newbies & FAQs 8 08-18-2004 01:59 PM
WRX injextors w/safc or rrfpr cvcsmkr Engine Management & Tuning 3 11-21-2002 09:32 AM
