Old 10-28-2000, 02:57 AM   #1
V6
Member#: 2703
Y2K GC8
Silver forever
Question How much ATF needed?
Hi,
Just like to know how much ATF is needed for the automatic transmission fluid change?
Also what is the difference between transmission oil and ATF?
Thanks.
V6 is offline   Reply With Quote
Old 10-28-2000, 09:37 AM   #2
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Post
The manual says the capacity is 8 quarts, but you won't be able to drain nearly that. I usually get about 6 quarts in there -- buy 7 just to be safe. Don't overfill it otherwise you will be black flagged at Thunderhill for making smoke on left hand turns due to leaking ATF!
ATF is oil, just a very specific kind that both lubricates and provides enough friction (viscosity) to make the torque converter work. People really ought to change their ATF more often than they do.
Necromancer is offline   Reply With Quote
1.8 sec 60' times. How much power needed? reddevil Proven Power Bragging 14 04-12-2005 08:57 AM
Oil change -- how much oil needed? lola Service & Maintenance 13 01-16-2004 07:07 PM
How Much Skill Needed For Alarm Install?? chewbakarox Car Audio, Video & Security 8 02-07-2003 01:22 PM
How much ATF for a drain & Fill on 4EAT? Crashton Transmission (AT/MT) & Driveline 3 06-21-2002 10:33 PM
How much time needed to install TurboXS Stage 2? roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-23-2002 06:01 PM
