Old 10-27-2000, 05:59 PM   #1
HillbillyRS
Member#: 2501
Question Raising the redline?
Does someone make a chip or some other means to do this? Thanks in advance.
HillbillyRS is offline   Reply With Quote
Old 10-27-2000, 06:39 PM   #2
Nat
Member#: 759
2004 WRX
2000 SV650
Post
So far it looks like the only thing to do this is the TEC-2. $2-2.5K is a good bit of change just to rev higher......but it throws in a lot of advantages in spark and fuel control. Is there a reason you want to rev higher? On a stock (or even my 2.5" cat-back and intake car) I don't think that winding the motor higher will make any more power.
Nat is offline   Reply With Quote
Old 10-27-2000, 06:51 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Cobb Tuning is coming out with the HalTech E6K unit soon, hopefully. This will be able to control ignition timing, fuel, and a few others. Rev limiter included.
They also have cams out for the SOHC cars, and will soon be developing forced injection cams.
Old 10-27-2000, 07:49 PM   #4
HillbillyRS
Member#: 2501
Wink
The reason I want to go higher is because I plan on staying NA(save me the turbo lectures) and running Cobb's new cams as soon as he puts them out along with alot of head work, a bigger throttle body and better ignition. I just like NA power as opposed to forced induction
Old 10-27-2000, 08:04 PM   #5
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Post
HillbillyRS,
I wont lecture on turbos... but now a nice supercharger is almost like a na set up!
Seriously, if your patient enough, Cobb tuning is gonna hook us up big time! You will be able to do forged pistons, heads, cams and sky high redline (well probably not honda high but close enough )
BTW: WV is the bomb! I took my girlfriend and my wife (my car) out that way to tour the state last year. It was great. The perfect state for the perfect car.
Rich L is offline   Reply With Quote
Old 10-28-2000, 01:12 AM   #6
HillbillyRS
Member#: 2501
Wink
Rich, I do like superchargers, but until someone comes up with a quality setup I'm going to stay NA. Glad you like it down here. If you ever plan on coming down towards Charleston or even the Morgantown area give me a yell. I know tons of cop-free bad-a$$ two lanes in the Charleston area and a great road between Morgantown and Fairmont called state route 73. It's about 20 miles long and you only have to lift three times!
Raising the redline paulpas Other Engine Management 3 07-08-2008 08:39 AM
How can I raise my redline safely and semi-easily? Homemade WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-22-2003 12:28 AM
What will raise my redline???? Tattoo Collector Engine Management & Tuning 2 11-15-2002 10:42 AM
Lets talk about head work and raising the redline Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-14-2002 04:41 AM
Raising the redline. imprezive Normally Aspirated Powertrain 14 04-04-2001 10:02 AM
